It is currently Sat Nov 23, 2024 11:29 pm
Reply to topic  [ 2657 posts ]  Go to page Previous  1 ... 18, 19, 20, 21, 22, 23, 24 ... 89  Next
Didn't do anything per se, but I did go and pickup a '98 Explorer 4R70W tranny in Sedalia for a steal:)
What do you guys use to hold these things while you rebuild them?
Sat Sep 10, 2011 5:26 pm
Finished cleaning and painting my 5.0 short block.
Next is to clean (and polish?) the intakes and then reseal and reassemble it.
Sat Sep 10, 2011 6:19 pm
Got the cooling system completed with the addition of an aux temp gauge. I also replaced the radiator cap, which turned out to be a big mistake as I pissed fluid out all the way to work this evening. I will pick up a new on before the drive home in the am. Not sure why this happened but I went back on with a stant cap!! Jayson
74, MONEY EATER
Sat Sep 10, 2011 7:08 pm
Drove it...changed oil in transfer case...checked rear dif fluid...still a loud squealing while I drive. Any ideas...I noticed a couple grease fittings missing on u-joints. Also thought maybe the wheel bearings...I do know it's not the brakes.
Old EB 1966 I-6 170
New EB 1970 V-8 302
Next EB ? 5.0 EFI
Sun Sep 11, 2011 12:34 am
On further inspection I found a pin hole in the radiator banghead rant . Now to get it home and the damn thing off. Jayson
74, MONEY EATER
Sun Sep 11, 2011 6:10 am
Spent about 4 hours trying to get the doors to hang perfectly, got close, then got my grinder cut off wheel out and took off the door pillars when i checked out how much brand new door pillars are online.
Sun Sep 11, 2011 7:58 pm
Sun Sep 11, 2011 8:00 pm
Did some interior mods today.
Mon Sep 12, 2011 8:54 pm
Is that a gear you used as the knob? Looks cool....is it soft? Is that a light you installed overhead?
Phil....did you happen to get my email on the 4r70w?
Mon Sep 12, 2011 9:01 pm
Mon Sep 12, 2011 9:18 pm
Ch*** underhood light. I won't tell anyone.
Mon Sep 12, 2011 9:35 pm
Mon Sep 12, 2011 9:42 pm
Nice work Viper! My grandma gave me an old light like that. I think I still have it in my truck! Totally different design, but same principle. I like the gear design for the window crank!
Tue Sep 13, 2011 7:40 am
I "accidentally" found a new can of black DupliColor undercarriage coating in the garage yesterday and like any good Bronco owner, instantly thought about the wheel wells. 10 minutes later both the rears were perfectly black:) Completely changes the look. Attempted to do the fronts and realized I'd have to remove the tires. That got me to thinking about the rake my Bronco has....so called Melissa at the Hut and inquired on some 3.5" coils to correct it. Dana will bring them up tomorrow:)
Wed Sep 14, 2011 6:03 am
Got the radiator back in again. Need to run it for a while longer and see if anymore leaks apear. I also got my tires on and the rims polished. I am also going to finish the install of the rampage soft top since the weather is changing. Jayson
74, MONEY EATER
Wed Sep 14, 2011 11:01 am
went to the pull and pay hunting for an steel oil pan from a 5.0 Explorer..............no luck.
Did score a steel clutch fan assy though. What a bugger to get off though.
Sun Sep 18, 2011 4:33 pm
Put the new trans filter w/stock pickup tube from WH in, new gasket and fluids and so far no more leaks! Drove it around the block a few times and it was great. First time I've been able to drive it in months. Got the door latches put back in and the doors all put back together. Really nice to finally have working locks, latches and handles on both sides! Started looking into the next issues that I need to tackle but it was a really great feeling to at least have it back on the road again.
Sun Sep 18, 2011 8:30 pm
Resealed the 9" and the D44. Had to weld on some new metal on the front GLO cover as it'd been wore down from the rocks. Also found a problem with my rear brakes (started a thread), but I think I have the one resolved. Now all I lack to get it back going is a little more gear oil and a new driveshaft u-joint strap (what's a good source for those?). It was nice to work on the bronco for a change. Just hard to make the time these days.
Mon Sep 19, 2011 7:39 am
Found a broken window pillar on the drivers side up front, and my neighbor welded it up which took care of an annoying rattle. It was real pain getting the front window out, and then back in. I have been driving it to work on a regular basis. Jayson
74, MONEY EATER
Tue Sep 20, 2011 8:01 am
I had to reinforce my driver's side, exterior door latch rod. It keeps bending above & below the reinforcement sleeve. Nothing exciting there, just welded some 1/4-20 all thread across the weak spots. Sorry no pics.
Then I thought (never a good thing), while I'm in there. I might as well get rid of the parchment arm rests & metal door panels. They clash with my new seats. I must say, I am a bit jealous of the speaker pods. But continuing my "Summer of doing anything & everything cheap or free", I used what I had around.
First I cleaned & shot my inside door handle cups & arm rests with adhesion promoter. Then painted the arm rests with some vinyl spray paint we had at the shop & the cups with trim black.
Then cut some foam to match the panel (we get GM bumpers packed in this stuff):
And glued it to the door panel:
Then used some 3M #77 spray adhesive & glued on some speaker cabinet carpet I've had for years. I added Q-pads to help quiet the doors as well.
I also made a new panel liner out of the same foam sheet & spray glued it to the door before installing the newly, cheaply, refreshed door panels:
Really didn't do all this today, but got the door panels installed. My new seats may inspire me to fix up my interior finally.
Wed Sep 21, 2011 8:09 pm
Finally installed the correct GREEN insulator module, turned the key and fired her right up!
Yeah
Wed Sep 21, 2011 8:31 pm
Spent the last 3 hours putting in an inner fender apron. Not fun, should be shooting epoxy primer in a few weeks.
Wed Sep 21, 2011 9:59 pm
Thu Sep 22, 2011 8:12 am
Thu Sep 22, 2011 8:14 am
yesterday/ finished tacking my front bumpertogether then welded welded and welded. next is bending some tube and then grinding.
Thu Sep 22, 2011 8:17 am
No pics Brian?
Thu Sep 22, 2011 8:27 am
Thu Sep 22, 2011 12:02 pm
Thu Sep 22, 2011 12:05 pm
Sorry to hear about your turbo. Next time I have my air filter off, I need to see what condition mine is in. If you have to replace, no time like the present to upgrade...
Today's menu on my bronco is to install new caliper, finish filling front diff with oil, and see if I can find a subject to help me bleed brakes. Then she'll be driveable again! Then I need to look at wheel bearings on my tow rig...
Fri Sep 23, 2011 7:32 am
Fri Sep 23, 2011 7:59 am
Users browsing this forum: Google [Bot] and 2 guests
32,985,901 Views Powered by phpBB © 2000, 2002, 2005, 2007 phpBB Group.
