www.ColoradoClassicBroncos.com - View topic - 7/8-18 Left handed tap
It is currently Thu Nov 14, 2024 12:38 am
Reply to topic  [ 8 posts ]
Post 7/8-18 Left handed tap
Anyone have one or know where to find one? A member here, Curtis, just put new steering in his bronco with cheby one-ton TRE's. After welding, can't rethread the TRE's into the inserts so needs to clean them up a bit. Any leads appreciated!
Wed Sep 28, 2011 1:29 pm
Post Re: 7/8-18 Left handed tap
I'd check with a local machine shop. Our bodyshop painter's family owns a machine shop (not engine machining, they make parts & other manufacturing) and he has the tap & some machine/thread cutter that can do most any female thread pitch.
Chad
Wed Sep 28, 2011 6:29 pm
He said he'd checked with local shops, but they key is to find someone with a lathe...
Thu Sep 29, 2011 7:43 am
Where is he? I know a shop in Longmont that could probably do it.
Thu Sep 29, 2011 8:44 am
In the 'Springs here. Would prefer to find someone local of possible, but that may not work out. I just know he doesn't have a lot of free time, but I do not know how often get gets to Denver.
Thu Sep 29, 2011 8:49 am
I had to do the same thing to mine. What I do was make a tap out of the end of the tre. I cut a few angled grooves in it and just worked the tre in and out slowly with cutting oil.
Thu Sep 29, 2011 12:05 pm
With what did you cut the grooves did they wrap around the stud like flutes on a drill bit?
Thu Sep 29, 2011 1:04 pm
I just used a cut off wheel. Yea kinda like flutes in a drill bit. About the first 1/2 to 3/4" of the threads.
Thu Sep 29, 2011 3:59 pm
32,871,342 Views Powered by phpBB © 2000, 2002, 2005, 2007 phpBB Group.
