It is currently Sun Nov 24, 2024 3:07 am
Got it loaded on the trailer, ready for Chinamans!!
Fri Oct 21, 2011 8:18 pm |
Took it for a spin up to Winsor to deliver Royce's C4.
Fri Oct 21, 2011 8:43 pm |
airbur
Mon Oct 24, 2011 5:31 am |
not much really..........
cleaned up and painted the elusive 5.0 Ford steel oil pan and installed it
cleaned up the garage a bit to make it easier to work in
Mon Oct 24, 2011 5:51 am |
WestMuddy
Mon Oct 24, 2011 4:39 pm |
rdanford
Joined: Wed Sep 29, 2010 8:12 pm Posts: 169 Location: Windsor
Viper Built C4 was installed...WOW...new motor is awesome with the tranny working! Thanks again Phil!
_________________ Royce 1977 Bronco...EFI, ViperBuilt C4, PS, PB, cut with 33's - Rebuild coming 1987 Porsche 951...LS1 swap - SOLD 2006 4Runner V8 Sport Edition 1998 4Runner...DD with 333k and counting
Mon Oct 24, 2011 8:11 pm |
airbur
Drove it to Ace to pickup some bolts....on the way I turned the heater on to test for winter....damn that blower upgrade works wonders!
Mon Oct 24, 2011 8:20 pm |
Mon Oct 24, 2011 8:46 pm |
Havent done much. First time since 2001 that I didnt take it elk hunting. I must say it was pretty nice to drive the truck. But before I left I did look into why it wanders so bad down the road. Gonna build a track bar riser and ditch the drop bracket. It is flexing like crazy.
Tue Oct 25, 2011 8:12 pm |
D&D72
I brushed off about 8" of snow off mine for the 1st time today.
Wed Oct 26, 2011 2:45 pm |
D&D72
Wed Oct 26, 2011 2:47 pm |
Wed Oct 26, 2011 2:58 pm |
Wed Oct 26, 2011 5:21 pm |
airbur
I didn't do anything to the Bronco today. I did install two 8 foot T8 florescent fixtures in the garage:) Total of 8 bulbs in there now...I can see! http://www.homedepot.com/Lighting-Fans/ ... ogId=10053
Thu Oct 27, 2011 7:47 pm |
airbur
I'm getting ready to do something similar. My entire garage is also on one 15 amp and when the compressor kicks on, it trips the breaker. I think I'm going to add a 20 amp breaker and run a line to a new outlet for the compressor and the heater.
Fri Oct 28, 2011 8:18 am |
Just set a 100 amp sub panel in the garage. That's what I did in boogers garage. Every outlet is its own 20 amp circuit. Plus tons of lights and the heater.
Fri Oct 28, 2011 8:40 am |
Did a similar job on mine a couple years ago. Have (3) 8ft and (3) 4ft fluorescent and ran two new 4-gang 20 amp circuits between the doors on the garage. Been really nice. Everything in mine was also 15amp. weak!
Fri Oct 28, 2011 8:50 am |
airbur
I thought a about a sub panel...but since I still have a few open slots in the main one, I think I'll go the new circuit route instead. It's obvious that newer homes are not built with any hobbyists or mechanics in mind! 1 15Amp....bla!
Fri Oct 28, 2011 9:05 am |
I'm not done, but since everyone is bragging about the electric in their garage, I've set new 200 amp service to my entire home & ran a new 100a breaker panel in my garage. I haven't run the new circuits yet, just attached the old wiring to the new panel (don't tell the electric inspector). I do have an open electric permit to do my whole home, so the garage is going to have to be finished correctly. But I'll have plenty of room to grow after the inspectors leave. It will be nice. My whole home & garage were run off a 100 amp service, total. But since the home was built in 1882, and was still running some knob & tube when I started the upgrade, 100 amp was probably a lot when it was installed.
Chad
Fri Oct 28, 2011 12:17 pm |
D&D72
Fri Oct 28, 2011 2:14 pm |
Fri Oct 28, 2011 3:18 pm |
Fri Oct 28, 2011 7:14 pm |
D&D72
Fri Oct 28, 2011 11:26 pm |
fsharp1@live.com
Joined: Wed Jul 06, 2011 11:33 pm Posts: 26 Location: FIrestone CO
Started taking panels off today, Front clip ,Doors, hood etc. Hopefully tomorrow I can start draining all the fluids in preparations to yank the engine Trans and T-case.
_________________ "Friendship is like peeing on yourself: everyone can see it, but only you get the warm feeling that it brings." !974 Bronco, 4x4, 302/ auto trans, All original for now
Sat Oct 29, 2011 7:44 pm |
Shawns Fords
Did a whole bunch of brake work on my F250 and when I was going through a tool box of parts I found an old Window crank handle from my 64 F100. I thought to myself "I sure could use my vise grips today" so I took the vise grips off of HULKs drivers door window crank and installed the handle. I really did do this today too. Oh I did think about Calling Greg to see if he had a hammer and a block of wood I could borrow to get my vice grips loose.
Sat Oct 29, 2011 9:07 pm |
I followed my inner lemming and replaced a shop light that had burned out. I also finally got around to installing a 250w metal halide that I'm not using on my aquarium out in the shop. I'm hoping that in addition to providing blinding amounts of light that it will also keep me warm. Used all that new light to take out my heater box and disassemble both it and my spare to take the best parts for a newly sealed, rebuilt heater. Picked up the parts yesterday for the upgraded motor and squirrel cage.
Sat Oct 29, 2011 9:22 pm |
Moab Mike
I bought a 1997 Ford Explorer motor complete with all the peripheral's. It has the GT40 (P) heads and upper/lower intake, yada, yada, yada. I get to pick it up next Saturday.
Sun Oct 30, 2011 8:46 pm |
Sun Oct 30, 2011 8:49 pm |
rdanford
Replaced front bump-stops and sealed up the interior a bit better for the winter
Sun Oct 30, 2011 8:59 pm |
Mon Oct 31, 2011 7:07 am |
