Postby Gunnibronco » Tue Nov 01, 2011 4:05 pm
Put a new block heater plug on. My BCB headers finished off what was left of my old plug.
Plugged in & set my outlet timer to have my engine warm in the morning.
Bring on winter!
Postby Jesus_man » Tue Nov 01, 2011 4:17 pm
It was Sunday, but aired up to street pressure and used my OBA to blow out my lawn sprinklers!
Chad - at one point I was trying to come up with a device that used a timer as well as a thermostat for your block heater.
Postby Gunnibronco » Tue Nov 01, 2011 4:34 pm
I just have mine fire up about 2 hours before I go to work. Starts every time, even at -20 or -30. The only days I have to drive my Chrysler is when ice freezes my doors or locks shut.
Chad
Postby akaFrankCastle » Tue Nov 01, 2011 5:42 pm
My Bronco apparently moved from the street to my driveway despite my being in Tampa, Florida. I guess a water main broke in the street under or near my truck. A CS Utilities worker and FJ40 owner was kind enough to pull it in the drive for Frau Castle.
Postby Gunnibronco » Fri Nov 04, 2011 5:51 pm
Today, its not what I did, its what I got:
1. Brand new Motorcraft EFI dizzy w/cast iron gear
2. one of these: http://matcotools.com/catalog/product/6 ... D-DIE-SET/
3. Tracking number of shipment containing rebuilt A9L computer
Hard to beat that.
Chad
Postby Justin » Sun Nov 06, 2011 1:30 am
Just finished up my heater box re-seal with blower motor and squirrel cage upgrade. I haven't run it yet with warm coolant, but holy crap that fan moves a ton of air.
Postby Gunnibronco » Sun Nov 06, 2011 8:02 am
Justin wrote:Just finished up my heater box re-seal with blower motor and squirrel cage upgrade. I haven't run it yet with warm coolant, but holy crap that fan moves a ton of air.
C***y fan? I've got one on the way. I'm looking forward to defrost that works.
Chad
Postby Justin » Sun Nov 06, 2011 8:20 am
Yup. If you don't have one on the way already, do the squirrel cage as well. It's a decent chunk bigger. Mine was blowing dust around the interior that may not have moved in the last 40 years.
Postby Gunnibronco » Sun Nov 06, 2011 8:31 am
Postby Booger » Sun Nov 06, 2011 12:36 pm
Opened the door and searched the console for the tire pressure gage then thought about what else I'm gonna do to 351W if I replace the heads. Gotta pull it out anyway since I think I need to replace the flexplate because the thing makes a funny sound when starting. Also noticed it starting to smoke when first started indicating valve seals and / or guides. It doesn't have but 15 or 20k on it since it was rebuilt and installed back in '96. Would like to go roller cam and efi as well. C4 needs Viperized as well. Then it needs a cage, some rust cleanup and repaint and...........
Postby Gunnibronco » Sun Nov 06, 2011 12:51 pm
Booger, keep me in mind if you do something radical. I decided to sell my Explorer 302 block, because if I'm going to swap motors I want a 351. So....... I'd be in the long term market for some builders parts if you end up with any. Just saying.
Chad
Postby Booger » Sun Nov 06, 2011 4:56 pm
Chad I'll you in mind as things start going that direction. Gonna be a few months yet, gotta get into the meat of winter before I start doing anything.
Postby Gunnibronco » Sun Nov 06, 2011 6:17 pm
Sweet, I shouldn't even be thinking about 351s, and just concentrate on getting my old 302 EFI'd.
Postby Jesus_man » Mon Nov 07, 2011 8:05 am
Friday afternoon, pulled the bent fitting off my steering ram, ran to the parker store for new fittings. Tonight - install fittings and bleed system. Hope it's that easy!
Postby landshark » Mon Nov 07, 2011 8:41 am
Pushed the bronco into the clean garage! ya pushed :(
Postby Justin » Mon Nov 07, 2011 6:37 pm
Saw a orangeish, reddish bronco with a white Bestop and white soft doors on 33's in the Safeway Parking lot at 287 and Arapahoe. Anyone here?
Postby Gunnibronco » Sun Nov 13, 2011 10:16 am
Yesterday I put in my new C***y heater fan. It blows, big time.
My heater box is in bad shape. Took longer to patch & rebuild the mounting surface than anything else. The lower mounting flange, from about 4 o'clock to 8 o'clock stayed on the old motor. Pulled it off, tacked it together w/super glue, then used bumper repair tape & SMC fiberglass repair adhesive to stick it all back together. I think it will hold for a while.
Any extra heater boxes out there? I put a "wanted" ad up.
Chad
Postby socofn » Sun Nov 13, 2011 5:45 pm
Spent 8 days in Ohio City hunting the mythical creature called "ELK". drove the Crap out of the Bronco and it did wonderful. It was snowy and muddy. I chained up the front end and it tried to climb a couple of trees but did find on trail that was akin to a bobsled course that kicked my a++. I had to break out the come along (no winch yet) and get out of the water bar hole I was in. I drove it everyday and boy did the heater upgrade come in handy. I will post some pictures of the bronco on the hills and covered in mud (man I need to get the fender flares on). JP boardin
74, MONEY EATER
socofn
Postby Gunnibronco » Sun Nov 13, 2011 5:56 pm
socofn wrote:Spent 8 days in Ohio City hunting the mythical creature called "ELK".
We call them "Ghost Elk". They seem to appear & disappear into thin air! Sorry you didn't have any luck, me neither. Oh well there is always next year. My friend found a 7x8 set of elk antlers this week. They are all palmated & absolutely HUGE! The bases are 12" circumference. I have a pic on my cell phone, but don't know how to post it.
Postby socofn » Sun Nov 13, 2011 6:40 pm
We did find a nice 6X6 skull who looks like he was shot earlier in the season. I did see lots of elk this year but missed once on a running shot and had a misfire. All in all we had a great time. JP
74, MONEY EATER
socofn
Postby landshark » Sun Nov 13, 2011 6:46 pm
I went to the junk yard... again for the 2nd straight day and pulled a double vbelt pulley and alt.. and it works! now to figure out where the air pump is routed to...
Postby Rox Crusher » Mon Nov 14, 2011 5:42 am
tinkered with the 5.0 some more
Postby Jesus_man » Mon Nov 14, 2011 7:29 am
Gunnibronco wrote:
socofn wrote: I have a pic on my cell phone, but don't know how to post it.
Send a text message to your email and then download it to your computer and upload here.
Postby Justin » Mon Nov 14, 2011 11:51 am
Threw a new coat of paint on the roll cage I got from Trei and started prepping for the install.
Postby Gunnibronco » Mon Nov 14, 2011 12:18 pm
Being in Gunnison for 16 years, I'm about 15 years behind on technology. I can't even figure how to email it to me. Honestly, I can barely text.
Feeling slightly stoopid.
Chad
Postby crawlercreations » Mon Nov 14, 2011 12:59 pm
Removed doors, removed tailgate, removed front clip, removed core support and front fender Wells, removed dash, removed windshield, removed windshield frame and picked up about 600 lbs of metal fire fire
Postby Viperwolf1 » Mon Nov 14, 2011 10:52 pm
Washed the blood and mud off it.
Postby hockeydad4-22 » Tue Nov 15, 2011 6:35 am
Viperwolf1 wrote:Washed the blood and mud off it.
Congrats! Looks like a successful hunt.
Postby Gunnibronco » Thu Nov 17, 2011 5:14 pm
Today was a great day. Mike (76fordbronco) drove all the way to Gunnison to deliver me a bunch of goodies, and take a bunch of my goodies back to folks in Denver. It was fun digging through all the new stuff I got, and I started cleaning up my new rims, getting them ready to paint.
Its great that some of my unused stuff has found new homes in the Bronco family.
Thanks to Zilla, Briannut, rtreads, Rox, Plumbdoctor, 68bronc, Kinder, JTSbronc, & cpldavis37. Thanks for the stuff & thanks for taking & using my stuff.
But most especially, a big thanks to Mike for going above & beyond. This is one of the nicest things anyone's done for me. Really, above & beyond!
Chad
Postby Rox Crusher » Thu Nov 17, 2011 5:43 pm
Got some goodies from Jegs.
Unfortunately the snooper doper razor "no mess" oil drain plug didn't fit.
Damnit all to hell
Return to Chit Chat
