It is currently Tue Oct 01, 2024 5:28 am
Reply to topic  [ 386 posts ]  Go to page Previous  1, 2, 3, 4, 5, 6, 7, 8 ... 13  Next
Here's the area that needs more work. Turns out I can pretty much remove the wall next to that hole and be ok....it's apparently a marker hole for Ford and has no use.
Sat Nov 12, 2011 5:30 pm
You're going to be an expert on Windsor blocks soon-whether you want to be or not!! "marker hole"... : )
Any other holes need trimming?
Sat Nov 12, 2011 10:22 pm
Sun Nov 13, 2011 12:01 am
Sun Nov 13, 2011 9:25 pm
You can find the "allen head" 1/4 NPT plugs at any hardware or good auto parts store... easy find. No teflon, use good pipe dope or if boys at SBFtech say so, use blue loctite.
Sun Nov 13, 2011 10:58 pm
Mon Nov 14, 2011 7:12 am
I would try to radius the sharp corner in the lower left of the hole you ground out.
That sharp of a corner could create an opportunity for a crack to develop.
Mon Nov 14, 2011 7:51 am
Mon Nov 14, 2011 7:54 am
Mon Nov 14, 2011 6:02 pm
Yep....odd sizing. I picked up the tap and used a socket to tap the holes. Worked perfectly. Also got some brass plugs and installed them after the wash.
Mon Nov 14, 2011 6:05 pm
NPT is used on all pipe fittings for water & gas (galvanized & black). I threaded a lot of 1/2" & 3/4" NPT when I was running gas lines for stoves & fireplaces. I think the taper must allow for a better fluid seal.
Chad
Mon Nov 14, 2011 6:08 pm
So the marker hole next to that cylinder p r i o r to the installing the cap screw rods didn't need to be clearanced but with them you needed to hog it out that far? Interesting...
Do you have the complete specs to your cam handy?
Mon Nov 14, 2011 11:36 pm
Tue Nov 15, 2011 6:04 am
After some final prepping, block is ready.
Tue Nov 15, 2011 7:06 am
Looking good for sure! This time, yeah...this time it's gonna stay together!! : )
I thought I saw the cam specs once, missed them when scrolling thru ... thanks. I'm going to enter the #'s into some software...
Tue Nov 15, 2011 7:46 am
Tue Nov 15, 2011 7:50 am
Here are a couple shots before I did the final grinding. These notches were not an issue with the previous rod bolts.
Tue Nov 15, 2011 8:41 am
One more...
Tue Nov 15, 2011 8:42 am
I dropped the rotating assembly off at CAMResearch today for re-balancing so work is at a standstill. Turn around time he says is early next week....I'm going to call and see if I can get it by Friday afternoon.
Tue Nov 15, 2011 3:41 pm
ADHD here.... boardin I don't sit well... where are those pistons and rods?? : -)
Got bored waiting and installed a ZF/203/D20 into a Bronco buddy's rig Sunday and finished up last night. It's not completed (clutch master cylinder and linkage still) but since I couldn't sit around and drool at the pics of your rig, I had to do something over the weekend!!!
Are you supposed to get them back for the long weekend? Hope so!
Tue Nov 22, 2011 9:50 pm
Picked up the balanced assembly yesterday:). Almost bought a windage tray there to but I don't have the main studs for it so not sure.
Thinking about ordering up some individual ARP studs for it.
I'll start the assembly this afternoon.
Nice work on that Bronco! Any pics?
Wed Nov 23, 2011 6:03 am
Got one piston installed today.....it clears perfectly:) Then I started fretting over the one oil galley plug that I think I installed slightly too far. I tapped the hole, but was concerned about having the plug be flush and now I think it's blocking an oil passage a bit. Working with the guys on sbftech to see if its an issue or not.
Wed Nov 23, 2011 6:24 pm
Glad you get to work on it this weekend...be tough sitting at home for 4 days... tough part should be over...all because of CHP...
Old pics in my rig, but no pics of the install Sunday...heck, the camera was even sitting on the mobile workbench...we were booking! Loaded his EB on his trailer a bit after midnight Monday(Tues am)... open headers, in the snow, towed it around to the hay field so we wouldn't wake up my wife!! She's very patient, but you can't push the envelope all the time!!! ;- )
Wed Nov 23, 2011 10:39 pm
Ok! Back on track:). Got all 8 cylinders and rods installed with bearings. Had to buy all new bearings at the recommendation of Woody at FordStrokers.com since the ones included in the CHP kit were crap and a smallish version. All the rod bolts clear by .060 or more.
I also shaved about 1/16" off the cam dowell and now the cam timing gear retainer bolt and washer sit nice and flat:). I did decide to do a windage tray so I ordered a Milodon version along with the necessary ARP main studs and nuts to mount it with.
Lastly, I called up Melissa at the Bronco Hut and she put in a order for the classic hood bubble as well as the Canton rear sump oil pan, pickup, and dipstick.
http://www.summitracing.com/parts/CTR-16-670/
http://www.summitracing.com/parts/MIL-32217/
Fri Nov 25, 2011 5:29 pm
Some pics...
Fri Nov 25, 2011 5:30 pm
Scoop (without the holes for now)...
Fri Nov 25, 2011 5:38 pm
Scoop's gonna look cool, but what happened to your block? Looks like it's got hives or somethin'... bumps all over it... :)
Is the pan one or two qts more capacity?
Fri Nov 25, 2011 9:13 pm
Fri Nov 25, 2011 9:33 pm
That pan will help keep things cooled down a bit more... can't go wrong, good idea
Sat Nov 26, 2011 1:06 am
Couple pics...(hosted on my private server Dan:)
Sat Nov 26, 2011 8:37 am
32,408,571 Views Powered by phpBB © 2000, 2002, 2005, 2007 phpBB Group.
