www.ColoradoClassicBroncos.com - View topic - Carpet insulation ideas
It is currently Sat Nov 23, 2024 3:17 pm
Reply to topic  [ 16 posts ]
Images: 1
Post Carpet insulation ideas
Im looking for carpet insulation that does a good job of eliminating some road noise as well as keeps the bronco cool/ warm, depending on season. I see there some products out there bronco specific. I have a feeling you can get the same material somewhere cheaper and just cut it out yourself. Anyone have some ideas.
Fri Nov 25, 2011 11:36 pm
Images: 1
Post Re: Carpet insulation ideas
That's exactly what I was lookin for. Cool thanks.
Sat Nov 26, 2011 9:04 am
Images: 1
Taaaadaaaa!
Still need to do some water proofing on the drivers side before lay it down.
Sun Nov 27, 2011 1:25 am
Nice work Shane!
Sun Nov 27, 2011 6:25 am
man, yoiu don't mess around
looks great
Sun Nov 27, 2011 7:42 am
Nice! I see you even did the doors. You don't mess around.
Sun Nov 27, 2011 11:33 am
Images: 1
Sun Nov 27, 2011 11:52 am
Thats the stuff Im gonna use all over. I plan to do the insides of the doors and top as well.
Sun Nov 27, 2011 6:42 pm
you guys have any problems getting the carpet hold down screws through the material?
Mon Nov 28, 2011 10:17 am
Any concerns with water if you run without the top on? I was thinking of doing something like this but worried it wouldn't last long through a couple of rainy days.
Mon Nov 28, 2011 11:38 am
Tue Nov 29, 2011 1:34 pm
Has anyone tried this stuff out in place of the factory firewall insulation? Mine is falling apart and I'm wondering if this would be a cheap way to replace it.
Fri Dec 02, 2011 11:50 pm
Did you guys use one roll or two rolls of the metallic insulation? Did you get special duct tape?
Wed Jan 11, 2012 11:20 am
you know what i have some thermal foil tape if you need some.. My wife works for a materials/tape company that supplies Lockheed, boeing and ULA.. the tape is used in thermal applications for aircraft and space stuff.. so should be pretty good. I will have the see how much i have but i can get more.. it should stick pretty well without peeling up and it should seal the insulation pretty good without getting all gooey and stuff
Wed Jan 11, 2012 11:25 am
Cool - I will hit Lowe's at lunch today. I am doing the carpet install this weekend so I will post up pics of the insulation and (Landshark) carpet install. I was not going to add carpet to my Bronco when it I thought I had to buy a $150.00 insulation kit. Thanks a ton for posting up this cheaper alternative.
Wed Jan 11, 2012 12:41 pm
Images: 1
I am still in the process of water proofing my firewall. All the sealing adhesive or caulking was melted away when the my bronco was burnt to a crisp. Having to yank everything off the firewall to lay a good bead on all the crevices. Not going to spend a bunch of money on carpet for it to be ruined in a year.
Bad part is I was welding up the hole for the clutch rod I end up melting my nylon clutch line banghead
On my clutch setup there's no bleed screw and its a bitch to get bleed out. You have to get a complete master, slave, reservoir, and line assembly all pre bled from dodge. $230 later. Damn you mopar!
Make sure you look on the other of what your welding. It could have been worse. bangtard
Wed Jan 18, 2012 2:06 am
32,975,188 Views Powered by phpBB © 2000, 2002, 2005, 2007 phpBB Group.
