www.ColoradoClassicBroncos.com - View topic - UUUUUUGGGGGGGHHHHHHHHH
It is currently Fri Nov 15, 2024 1:01 am
Reply to topic  [ 19 posts ]
Post UUUUUUGGGGGGGHHHHHHHHH
So my bronco wont start now. I can here the solenoid engaging but for some reason nothing at the starter. Also the radio does not work while its in run or accessories but when you turn the key to the left it turns on. First click to the right the efi fuel pump turns on but when you go to start nothing. I replaced the solenoid thinking it was a bad solenoid but nothing working.
Any help would be appreciated. Thanks people.
Bobby
Thu Dec 08, 2011 4:07 pm
Post Re: UUUUUUGGGGGGGHHHHHHHHH
Bad ignition switch...or connections.
Thu Dec 08, 2011 4:28 pm
Bad starter solenoid, test it by jumping the + battery cable to the small post closest to the + battery connection on the solenoid. I'm off tomorrow if you want me to come by, let me know.
Thu Dec 08, 2011 6:19 pm
Soleniods are cheap.....easy fix.
Thu Dec 08, 2011 7:20 pm
Is the battery dead? Are the clamps all nasty and corroded?
Thu Dec 08, 2011 7:24 pm
Thu Dec 08, 2011 10:39 pm
Napa, Advance both have them down here.
Thu Dec 08, 2011 10:58 pm
I had to go search my dads garage for one, I now carry a spare :)
Thu Dec 08, 2011 11:02 pm
Almost every Advance has one....
Thu Dec 08, 2011 11:13 pm
Sweet!
Fri Dec 09, 2011 1:02 am
Fri Dec 09, 2011 6:47 am
I had replaced the solenoid all ready. Terminals look fine but I guess I could Clean them. Thanks for the help and I will let you guys know.
Fri Dec 09, 2011 7:05 am
Have a load test done on the battery, or easier yet, jump it and see if the bronco turns over. That should tell you if the battery is at fault or it's connections.
Fri Dec 09, 2011 8:57 am
Images: 1
ground at block ?
Fri Dec 09, 2011 10:21 pm
Images: 1
If you have a volt meter make sure you have voltage at the starter when cranking. May need a helper to crank while you test. If you have good voltage at the starter then your starter pooped out. The solenoid on the fender when cranking sends a good 12 volts to the starter with a decent battery. Definitely make your not losing voltage through corroded cables.
Fri Dec 09, 2011 10:39 pm
Any update?
Sun Dec 11, 2011 1:00 pm
Well I think the battery is almost dead or the cables are fried. I will take the battery in tomorrow and get a check up and charge and see whats going on. The battery is only a year or two old so I doubt its bad but you never know.
Sun Dec 11, 2011 9:00 pm
It doesnt matter how old they are. If you have let it die there may be a chance that it never fully charged back up.
Sun Dec 11, 2011 9:08 pm
Mon Dec 12, 2011 10:54 am
Users browsing this forum: Google [Bot] and 2 guests
32,882,224 Views Powered by phpBB © 2000, 2002, 2005, 2007 phpBB Group.
