It is currently Sat Nov 23, 2024 11:45 pm
Reply to topic  [ 2657 posts ]  Go to page Previous  1 ... 24, 25, 26, 27, 28, 29, 30 ... 89  Next
Got the heater mounted and installed a 20A outlet...
Sun Dec 04, 2011 4:48 pm
Sun Dec 04, 2011 4:55 pm
Sun Dec 04, 2011 5:46 pm
Sun Dec 04, 2011 6:04 pm
Sun Dec 04, 2011 7:07 pm
Got the Bronco into the garage and started pulling her apart! This is going to be fuuuuuuuuun!
Mon Dec 05, 2011 9:48 am
Preparing to snow bash and get a Christmas tree this weekend! For the last umpteen years it's never been worth the effort to drag my bronco along until this year!! Can't wait!
Mon Dec 05, 2011 9:55 am
Pulled the 45K off the ceiling and then reconstructed its box with packing tape. Returned to Lowes and got the 75K:). Got it put together and hoisted back up. Need to run the thermostat line now.
Mon Dec 05, 2011 6:06 pm
Yea....looks a lot beefier hanging up there. Cant wait to fire it up.
Mon Dec 05, 2011 9:55 pm
Shoot, we have been working in the garage until 9-10pm every night the last few weeks, we heat with 4-6 hallogen lights, a portable electric glow heater, 4.5" angle grinder and a lincoln wire feed welder... yes we are wearing insulated cover alls etc, but hey - it works for us. No special wiring or plumbing required.
Tue Dec 06, 2011 8:50 am
Tue Dec 06, 2011 8:59 am
Countdown...
Wed Dec 07, 2011 7:18 am
Since I haven't even started it since the platte meet I figured id check the battery. Went out and turned the key on. Let the fuel pump fill the carb. 2 pumps of the pedal and hit the key. Fired up instantly. Let it run a few minutes. Got to love ol reliable.
Wed Dec 07, 2011 8:16 am
Wed Dec 07, 2011 9:43 am
Hmmm, may need to upgrade to an electric fuel pump. I hate cranking mine for a week to fill the carb if its been sitting.
Wed Dec 07, 2011 11:43 am
yeah, the electrical pump sure is nice!
Wed Dec 07, 2011 11:48 am
Wed Dec 07, 2011 8:17 pm
Dropping tank to figure out why I'm not getting any fuel pressure
Royce
2006 4Runner V8 Sport Edition
Sat Dec 10, 2011 8:17 am
Garage heater just kicked on...all by itself (or maybe cause I have the thermostat set for 65f at 7am on Sat:)....so I guess that means I need to head out to the garage and get working:)
Sat Dec 10, 2011 8:20 am
Fuel pressure issue solved...hose in tank split in half.
Royce
Sat Dec 10, 2011 6:27 pm
60's are in. Some items to button up (brakes, shock mounts, lockers and gears) then time to go snow bashing and see what i can break!!!
Sat Dec 10, 2011 7:23 pm
Insulated the garage....not a fun job.
Sun Dec 11, 2011 5:09 pm
rdanford - heeps have this problem a lot. The hose in the tank is generally not rated to have fuel on the outside and therefore deteriorates. Sounds like you had the same problem and may again, unless you can find the hose rated for fuel on the outside as well.
kchaser - nice work! Can't wait to see your rig in action!
airbur - garage is looking nice! 65 is nice and toasty for a shop!
Me? I just took it to get a Christmas tree, did some snow bashing! Was fun!
Mon Dec 12, 2011 10:59 am
Thu Dec 15, 2011 7:14 pm
Finally got my paint mixed right & painted my "new" rims. I mixed up some single stage gray that came close to matching Audi's dark gray bumpers. I think the top, grill, and probably the hood bubble (really I'm waiting for the Zillacon/American Rock Rod hood louvers- whats up with that Dan?) will get painted to match. I'm going to try to get rid of all the white in the long run. Sorry, no camera, I'll take some pics tomorrow. Hopefully be able to swap my tires to the new rims next week.
Chad
Fri Dec 16, 2011 6:07 pm
Here are some pics, didn't want to wait 15 minutes while the booth lights turned on so they are dark. I couldn't get paint into the crack between the inner & outer rim, so there is a little white poking through. I may try to touch this up, or I may just leave it as is, I don't think you'll ever see it once things are mounted & installed.
Sat Dec 17, 2011 11:16 am
You could get some paint in that crack with a small brush
Either way, those look 100 times better than when you got em
Sat Dec 17, 2011 11:27 am
Sat Dec 17, 2011 11:31 am
Started installing the WH 4.5 rear springs today. Got the passenger side done but I am missing half a bushing. banghead I will call WH on monday and have them send me what is missing. Not to hard a job just needed some finesse at times. Jayson
74, MONEY EATER
Sat Dec 17, 2011 6:43 pm
Didnt do anything to the bronco again but I did work in my garage. A couple months ago I scored a corian counter top from work. It was going in the trash so I took it. Today I built it into a work bench. Then pulled the fuel bowl off the PSD to rebuild/reseal it up to fix the fuel leak. That didnt go so well. I tapped out the pressure relief seat and it went flying across the garage and I cant find it. So now Im without a truck until I can order a new one.
Sat Dec 17, 2011 6:47 pm
32,986,181 Views Powered by phpBB © 2000, 2002, 2005, 2007 phpBB Group.
