It is currently Sat Nov 23, 2024 10:43 pm
Sat Dec 17, 2011 11:29 pm |
Sun Dec 18, 2011 10:28 am |
cool, well i will gather up what i have and take them over there.. wanting to por-15 everything pretty soon...
Sun Dec 18, 2011 11:05 am |
JGZ
I've got a big blast cab.Might need some new media and it's out side so it might be kinda cold.If you need to use it let me know.JGZ
Sun Dec 18, 2011 1:39 pm |
airbur
BlastTech does great work but they are pricey. I had my axles done there as well as a bunch of other parts. I just had them do the 2 Explorer serpentine brackets with bead media...$15 which wasn't bad.
Sun Dec 18, 2011 5:13 pm |
Started building my new roll cage today! Coming along pretty nicely!! :-) Built and installed my new rock slider on the passenger side to match my new drivers side. Oh and started narrowing my hood 10".
Sun Dec 18, 2011 6:09 pm |
Sun Dec 18, 2011 8:19 pm |
socofn
Got the springs of the drivers side, but needed the grinder and a BFH as the bolt was rusted to the middle metal spacer, which then took a press and a sawzall to get the rest out. What a pain in the a**. JP
Sun Dec 18, 2011 8:26 pm |
Moab Mike
Put a new ignition coil in and now I can't find my heat shrink tubing so I can solder the wiring together on the new coil connector. I also installed a new e-brake cable from Tom's that was about 2" too fawking short. AND I found out I'm missing two Snap-on wrenches from a couple of pull and pay excursions................Just another day in paradise.
Sun Dec 18, 2011 8:31 pm |
airbur
Well that sux! If you had bought them from the Bronco you could have new ones tomorrow:).
Sun Dec 18, 2011 8:36 pm |
Sun Dec 18, 2011 8:55 pm |
Found that damn missing piece from a fuel bowl from yesterday. So I got that put back together and on the truck. No more leaking fuel all over.
Sun Dec 18, 2011 9:16 pm |
Building a new upper half to my drivers side door since the last one blew out on the highway...
Mon Dec 19, 2011 7:55 am |
kchaser
Joined: Sat May 07, 2011 5:54 pm Posts: 269 Location: Wellington
Finally made some progress on the shop so I can get something done on the Bronco in MY shop
Wed Dec 21, 2011 10:46 pm |
ordered a bunch of goodies from BC Broncos.................
Wed Dec 21, 2011 10:47 pm |
Dropped the new window frame for my soft doors off at the upholster. Hope she can finish before the snow run!
Thu Dec 22, 2011 9:43 am |
I put more parts in the back of it (DS floorboard in this case) that I don't have time to install...stupid house needs to sell so I can have more time to play.
Thu Dec 22, 2011 11:23 am |
Rolled a 351W from a 96 F250 off a freight truck, into our shop. Pulled the plugs, shined a light down the cylinders, all looked good, still can see crosshatching in the cylinder walls. Wow there is a lot of crap on this motor that I don't need, much more than the Explorer 5.0.
Had to attend to worsening plumbing problems, so the EFI swap took a night off. On the plus side, the plumbing problem is fixed with less work than I expected. Note to self: don't clean drywall tools in the bathtub, use a hose, outside. I suppose none of you married guys would have gotten away with it, but here is a case where the nagging voice would have been right. I thought about it when I was doing it, weird, it took about 2 years to stop everything up.
Tue Dec 27, 2011 7:51 pm |
socofn
Finished installing my rear springs and took the dogs for a short drive thru the snow. I plan on driving it the next couple of days. JP
Tue Dec 27, 2011 7:54 pm |
Wed Dec 28, 2011 8:26 am |
Yesterday & today I spent my free time stripping all the junk off my 96 F250 351, and getting it bolted to a stand. I pulled the front accessories off the 351, what is the difference between the Explorer serp & the truck serp set up? Can the truck set up work in the EB?
I pulled the dizzy and found a steel gear, that means its a roller camshaft. I had read different opinions on if the truck motors had roller cams, and honestly I was expecting a flat tappet camshaft. I read the 351 rollers used the Explorer camshaft, is this right?
Another bonus, the ECT, TPS, and IAB were all the "old" style, so they match the RJM harness. I was going to use Explorer sensors that would need the pigtails swapped, but not now. I'm going to update my EFI thread with more progress & problems.
edit: also does anyone know if I wanted to keep my v-belt set up, could my waterpump bolt to this timing chain cover? The Flowkooler w/p I have is the same p/n as the 351. Or would I have to get an old style timing chain cover?
Thu Dec 29, 2011 8:53 pm |
Fri Dec 30, 2011 12:13 am |
Fri Dec 30, 2011 1:25 am |
Thanks for info, lots more to think about. Makes sense about the timing chain cover/water direction.
Chad
Fri Dec 30, 2011 8:31 am |
kchaser
Mon Jan 02, 2012 4:02 am |
sbolt19
Mon Jan 02, 2012 10:40 pm |
Are you cutting out all the pieces then welding them all together are breaking some?
Wed Jan 11, 2012 8:14 am |
Thu Jan 19, 2012 8:58 pm |
socofn
got my warflares installed on friday that I bought back in november. It does totally change the look. I am also looking for some 8inch wide wheels as I have 10's now and do not really care for the look with the 33's x 12.5's. JP
Sun Jan 22, 2012 6:46 pm |
What steering setup did you go with?
Tue Jan 24, 2012 9:56 am |
