It is currently Tue Oct 01, 2024 7:42 am
Reply to topic  [ 386 posts ]  Go to page Previous  1 ... 6, 7, 8, 9, 10, 11, 12, 13  Next
Sun Jan 01, 2012 6:51 pm
427W candy...
Sun Jan 01, 2012 9:21 pm
How is the screen attached to the p/u? Easily removed, if not then I'd also bend the pickup tube. You won't lose any strength. Just keep the face of the p/u parallel to the bottom of the pan. If you can remove the screen easily then you could very easily cut the pickup tube off at the rect. box it's welded to, cut it to length and then you're ready...
BTW, looking good!!
Mon Jan 02, 2012 12:35 pm
Mon Jan 02, 2012 12:41 pm
heat and bend... X2 Viperwolf said
You might discolor it when heating it but that's all, besides that's what photoshop is for! : )
Mon Jan 02, 2012 1:21 pm
Mon Jan 02, 2012 1:35 pm
So basically, I heat up the bend with a torch until it's red hot, then apply pressure on the pickup until it's about right? Or do I remove it, heat it up, use some type of round metal to create another bend?
I can't have the pickup move left or right at all as it will hit the baffle in the pan.
I'm thinking the bend at the arrow here:
Mon Jan 02, 2012 5:34 pm
Yup, looks like that will work. Might have to bend it at the next radius also...the one closer to the screen p/u.
Mon Jan 02, 2012 7:03 pm
Dull red, don't want the whole thing to drop in half... lol you'll be fine, be glad it's not aluminum...
Mon Jan 02, 2012 7:05 pm
Cool, thanks. Just bought a torch:) I posted on CB.com also to see what everyone else thinks.
Mon Jan 02, 2012 7:08 pm
So how'd it turn out?
Tue Jan 03, 2012 12:06 am
Tue Jan 03, 2012 3:13 am
They make brushes for cleaning aquarium parts that would be perfect for cleaning out the inside of that tube. Petsmart may have them, otherwise any of the specialty aquarium places will.
Tue Jan 03, 2012 8:36 am
Thanks guys. After talking with some others, I think I am going to go the cut and weld route. It would be quite difficult to get 3/8" from bending without affecting other clearances (pickup to tray etc.).
So who can cut and weld this thing for me? :)
Tue Jan 03, 2012 8:42 am
Wed Jan 04, 2012 7:23 am
.02 cents here...
How about buying a 351W stock van pan or a Bronco house parts pan and making it purdy by powdercoating it? Just a thought... about .02 worth really... :) Is clearance an issue? Might not have to move the oil pickup...
Sun Jan 08, 2012 9:29 pm
Mon Jan 09, 2012 9:51 am
Hey Guys.....wanted to update all the loyal followers of my build. At this time I've sent the pickup, pan, and dipstick back to Summit Racing for a refund. Build is going to slow down a bit as I'm dealing with some fun unexpected homeowner-expenses right now. I'm to the point of needing to buy some expensive parts (heads etc). I'll post up when I get going again.
Wed Jan 11, 2012 7:16 am
Check your pm... screaming deal...
Thu Jan 26, 2012 6:50 pm
Cool...I'll check it out. This is what I've been up to.....
viewtopic.php?f=4&t=3307
Thu Jan 26, 2012 7:17 pm
Post Airbur's 427W Build Thread
I've ordered up the standard 351w oil pan kit (pan/pickup/dipstick) and it should be here soon. Hoping this one fits with little to no mods. I'm wondering about using silicone on the gasket. The gasket I have is one piece rubber. Do I put sealant on both the block and the pan or just the block side like the valve covers?
Sun Mar 04, 2012 9:00 pm
The one piece gasket shouldn't need silicone.
Sun Mar 04, 2012 10:05 pm
Mon Mar 05, 2012 8:51 am
id just do the corners by the rear main cap and the timing cover. Just a little dot in the corner and call it good.
Mon Mar 05, 2012 10:09 am
Mon Mar 05, 2012 9:28 pm
Tue Mar 06, 2012 8:18 am
How are things coming along? Any updates yet?
Fri Mar 09, 2012 10:22 am
Fri Mar 09, 2012 10:26 am
Speaking of oil pans, what pan is needed for the 351 swap? I got my motor from a 96 F250, and I haven't done the reading to know what pan I'll need to do my swap. Will the F250 pan work, or should I be looking for another? No stroker for me.
Fri Mar 09, 2012 11:04 am
Fri Mar 09, 2012 11:11 am
32,409,630 Views Powered by phpBB © 2000, 2002, 2005, 2007 phpBB Group.
