Postby tod » Sun Feb 19, 2012 9:56 pm
The GT40 lower is about .46" taller than the truck lower and BCBroncos adapter combined.
1966 Bronco - 408 roller cam, Explorer serpentine, NV3550 5spd, hydroboost, 35s, 4.56 gears
tod
Postby Gunnibronco » Sun Feb 19, 2012 9:57 pm
Interesting. You don't happen to have an extra, or a line on others? I know its a dumb question, but I have to ask.
Postby tod » Sun Feb 19, 2012 10:08 pm
No. I spent a long time looking for this one.
If anyone needs the BCBroncos setup, I would make them a heck of a deal though.
Gunnibronco wrote:Interesting. You don't happen to have an extra, or a line on others? I know its a dumb question, but I have to ask.
tod
Postby airbur » Wed Feb 22, 2012 7:52 pm
Replaced the connector for the temp sending unit. Replaced a fuse in my ohm meter. Looked at the disassembled tranny on my bench. Exciting stuff.
airbur
Postby airbur » Thu Feb 23, 2012 6:10 am
zillacon wrote:Been working on the Toy Tug to get it ready for the season. I got all 4 Frame Mounted Tork Lifts installed, that was a Biotch and installed the 5th wheel plug in the box. Cutting that 2" hole in a new truck was painfull but I'm glad it is done and its all ready to go.
Sweet! Now, say that again in English:)
airbur
Postby airbur » Thu Feb 23, 2012 6:21 pm
I removed the Corbeau 4 point harnesses and installed the regular 3 point retractables from WH. What a difference! These actually work great. The use the stock seat belt holes on the floor and you only need to drill one 1/2" hole about 35" up on each side of the cage. The buckle comes in a hard-plastic sleeve that you can bend and puts the connector right in the corner of each seat.
airbur
Postby kchaser » Sat Feb 25, 2012 5:19 pm
Put on my new Autolite 2bbl. Sad day when you remove a worked 670 Holley and put on a 2bbl just so you can go up a hill. It lost a little snot but not bad.
kchaser
Postby Booger » Sat Feb 25, 2012 5:44 pm
Got to run out some winch cable to re-spool it while pulling Steve's Bronco into Zoso's garage. Now I need a new roller fairlead. And then need to run a remote winch controls into the cab so I don't have to drag out the winch controller all the time.
Postby crawlercreations » Sun Feb 26, 2012 7:48 pm
Finished up the wiring and mounted my front clip permanently finally and got my dash mocked up and painted. Getting closer!
Postby Rox Crusher » Mon Feb 27, 2012 1:43 am
looking great !
Postby hockeydad4-22 » Mon Feb 27, 2012 7:11 am
crawlercreations wrote:Finished up the wiring and mounted my front clip permanently finally and got my dash mocked up and painted. Getting closer!
Let me tell ya, I am seriously diggin the tube front end. That is awesome.
Postby Moab Mike » Wed Feb 29, 2012 7:52 pm
Bought a complete operational Hickey Sidewinder III 9K lb. Winch with the original manual for $300.
Moab Mike
Postby Rox Crusher » Wed Feb 29, 2012 7:58 pm
76fordbronco wrote:Bought a complete operational Hickey Sidewinder III 9K lb. Winch with the original manual for $300.
hey, let's not BS folks.................
he bought a complete operational Hickey Sidewinder III in pristine condition
count me jealous !
Postby Moab Mike » Wed Feb 29, 2012 8:07 pm
I call!
Moab Mike
More
Moab Mike
Postby Viperwolf1 » Wed Feb 29, 2012 8:35 pm
Nice. What did it come out of, cause it wasn't a Bronco?
Postby Moab Mike » Wed Feb 29, 2012 8:42 pm
Viperwolf1 wrote:Nice. What did it come out of, cause it wasn't a Bronco?
1976 Jeep Cherokee
Moab Mike
Postby Viperwolf1 » Wed Feb 29, 2012 8:50 pm
You'll have to take a look at mine this weekend and see how the support structure is built.
Postby Moab Mike » Thu Mar 01, 2012 2:15 am
Viperwolf1 wrote:You'll have to take a look at mine this weekend and see how the support structure is built.
See you at Jeff's!
Moab Mike
Postby airbur » Sat Mar 03, 2012 12:31 pm
Stopped by RaptorRacer's today....he and his dad are installing the full Tom's Bronco Parts power steering conversion.
airbur
Postby airbur » Sat Mar 03, 2012 12:33 pm
See you at Jeff's!
What? A secret bronco meeting at Jeff's???
airbur
Postby Rox Crusher » Sat Mar 03, 2012 2:32 pm
airbur wrote:
See you at Jeff's!
Come on over anytime today or tomorrow
We are tearing tranny down today
Postby crawlercreations » Sat Mar 03, 2012 8:29 pm
I finally got my cage tied into the frame today! Took way longer than I wanted but it came out pretty good. 1.5" o.d. .25 wall tubing should be sufficient!! Cage is now tied into the frame from the very front to the very rear.
Postby Viperwolf1 » Sat Mar 03, 2012 8:49 pm
Rox Crusher wrote:
airbur wrote:What? A secret bronco meeting at Jeff's???
Mission accomplished.
I hope Jeff kept track of how it goes together because I have no idea.
Postby landshark » Sun Mar 04, 2012 9:01 am
Got my 9' back together yesterday finally... hoping to get the brakes put back on and all the lines then roll it out of the way and start back up on the body/frame touch up cleaning. hoping to start painting the frame this afternoon! - ohhh optimism is great!
Postby Gregg » Sun Mar 04, 2012 8:24 pm
I picked up some old (1970's --"Arkay" ?) box speakers for $2. Anyhow, they kick a$$ and they fit my budget.
Gregg
Postby hockeydad4-22 » Mon Mar 05, 2012 3:51 am
Lets see, we installed the throttle kick down, replaced the brights switch so now we have head
Lights, hung and adjusted the doors, installed a new windshield, cleaned all the glass, glued some of the lose weather seals in place.....
And drove it. seems to be burning rich, will need to adjust the carb.
Then we cleaned the garage. For the first time since october, hockey mom gets to park her car in the garage
Postby D&D72 » Mon Mar 05, 2012 4:43 am
Just in time for winter!
D&D72
Postby Rox Crusher » Mon Mar 05, 2012 4:45 am
hockeydad4-22 wrote:Then we cleaned the garage. For the first time since october, hockey mom gets to park her car in the garage
We have some truly understanding wives............
Postby hockeydad4-22 » Mon Mar 05, 2012 7:54 am
Not so much an understanding wife, but the boys have a very understanding mother, that is for sure!
Return to Chit Chat
Users browsing this forum: Google [Bot] and 8 guests
