It is currently Sat Nov 23, 2024 9:32 pm
Reply to topic  [ 2657 posts ]  Go to page Previous  1 ... 27, 28, 29, 30, 31, 32, 33 ... 89  Next
The GT40 lower is about .46" taller than the truck lower and BCBroncos adapter combined.
1966 Bronco - 408 roller cam, Explorer serpentine, NV3550 5spd, hydroboost, 35s, 4.56 gears
Sun Feb 19, 2012 10:56 pm
Interesting. You don't happen to have an extra, or a line on others? I know its a dumb question, but I have to ask.
Sun Feb 19, 2012 10:57 pm
Sun Feb 19, 2012 11:08 pm
Replaced the connector for the temp sending unit. Replaced a fuse in my ohm meter. Looked at the disassembled tranny on my bench. Exciting stuff.
Wed Feb 22, 2012 8:52 pm
Thu Feb 23, 2012 7:10 am
I removed the Corbeau 4 point harnesses and installed the regular 3 point retractables from WH. What a difference! These actually work great. The use the stock seat belt holes on the floor and you only need to drill one 1/2" hole about 35" up on each side of the cage. The buckle comes in a hard-plastic sleeve that you can bend and puts the connector right in the corner of each seat.
Thu Feb 23, 2012 7:21 pm
Put on my new Autolite 2bbl. Sad day when you remove a worked 670 Holley and put on a 2bbl just so you can go up a hill. It lost a little snot but not bad.
Sat Feb 25, 2012 6:19 pm
Got to run out some winch cable to re-spool it while pulling Steve's Bronco into Zoso's garage. Now I need a new roller fairlead. And then need to run a remote winch controls into the cab so I don't have to drag out the winch controller all the time.
Sat Feb 25, 2012 6:44 pm
Finished up the wiring and mounted my front clip permanently finally and got my dash mocked up and painted. Getting closer!
Sun Feb 26, 2012 8:48 pm
looking great !
Mon Feb 27, 2012 2:43 am
Mon Feb 27, 2012 8:11 am
Bought a complete operational Hickey Sidewinder III 9K lb. Winch with the original manual for $300.
Wed Feb 29, 2012 8:52 pm
Wed Feb 29, 2012 8:58 pm
I call!
Wed Feb 29, 2012 9:07 pm
More
Nice. What did it come out of, cause it wasn't a Bronco?
Wed Feb 29, 2012 9:35 pm
Wed Feb 29, 2012 9:42 pm
You'll have to take a look at mine this weekend and see how the support structure is built.
Wed Feb 29, 2012 9:50 pm
Thu Mar 01, 2012 3:15 am
Stopped by RaptorRacer's today....he and his dad are installing the full Tom's Bronco Parts power steering conversion.
Sat Mar 03, 2012 1:31 pm
Sat Mar 03, 2012 1:33 pm
Sat Mar 03, 2012 3:32 pm
I finally got my cage tied into the frame today! Took way longer than I wanted but it came out pretty good. 1.5" o.d. .25 wall tubing should be sufficient!! Cage is now tied into the frame from the very front to the very rear.
Sat Mar 03, 2012 9:29 pm
Sat Mar 03, 2012 9:49 pm
Got my 9' back together yesterday finally... hoping to get the brakes put back on and all the lines then roll it out of the way and start back up on the body/frame touch up cleaning. hoping to start painting the frame this afternoon! - ohhh optimism is great!
Sun Mar 04, 2012 10:01 am
I picked up some old (1970's --"Arkay" ?) box speakers for $2. Anyhow, they kick a$$ and they fit my budget.
Sun Mar 04, 2012 9:24 pm
Lets see, we installed the throttle kick down, replaced the brights switch so now we have head
Lights, hung and adjusted the doors, installed a new windshield, cleaned all the glass, glued some of the lose weather seals in place.....
And drove it. seems to be burning rich, will need to adjust the carb.
Then we cleaned the garage. For the first time since october, hockey mom gets to park her car in the garage
Mon Mar 05, 2012 4:51 am
Just in time for winter!
Mon Mar 05, 2012 5:43 am
Mon Mar 05, 2012 5:45 am
Mon Mar 05, 2012 8:54 am
32,983,822 Views Powered by phpBB © 2000, 2002, 2005, 2007 phpBB Group.
