Register •
FAQ
• Login
It is currently Sun Sep 29, 2024 11:31 am
[ 6 posts ] |
68BRONC
Joined: Sat Apr 30, 2011 11:31 am Posts: 26 Images: 0 Location: Highlands Ranch, CO
Door Hinge Rebuild?
Has anyone ever tried to heat and press out the pins in your old, warn-out, and wobbly door hinges? The hinges looks to be in good condition. The pins are what appears to be worn out, rusted, and thin. I just wondered if it was possible (read: worth the effort) to attempt to press the old pins out and replace with new nylon washers and hardened pins. Any thoughts?
_________________ Andy Schwartz 303-656-6123 andyschwartz@outlook.com
Lubr, 3.5"WH, 31x10.50 DuraTrac, 15x8 Slotts
Mon Mar 12, 2012 5:17 pm |
Broncoguy73
Joined: Mon Feb 20, 2012 10:09 pm Posts: 126 Location: Highlands Ranch
Re: Door Hinge Rebuild?
That's what I did on my 73'. I had to lift the door to shut it they were so bad. I took off the hinge and pressed out the old ones. I bought the hinge kit from one of the EB web sites. It worked out great!
Mon Mar 12, 2012 6:52 pm |
We pressed them out, drilled them and replaced the pins with grade 8 - 5/16 bolts. The result? Tight hinges that are easily removable.
Just did it a few weeks ago, we will let you know down the road if everything is still tight, but we figured there was no harm if the fix failed, the hinges were shot anyway.
Tue Mar 13, 2012 5:50 am |
sbolt19
I drilled mine out several years ago and put quick pins in them. They worked great for a while, but then they got sloppy after about 6-7 years of daily use. I ended up biting the bullet and buying the stainless lift off hinges.
Tue Mar 13, 2012 9:02 am |
68BRONC
Thanks for all the feedback. The hinges are sloppy but the doors still shut ok. I'm in the process of prepping for blast/body/paint work and don't want to have to deal with poor fitting doors. Hinges are just one more expense in a long list for this restoration. I don't have a press but would like to have the addition to the garage. So, its either new hinges or a press and hinge kit.
Thanks again! -Andy
Thu Mar 15, 2012 8:30 am |
sbolt19
Honestly, if I had it to do over again, I would have bought lift off hinges had they been available when I did mine, but they weren't, so I made my own. I used an air hammer to knock the old pins out, drilled it out and put the quick pins in. The stainless hinges that Wild Horses sells are great, I should know, #1 I have a set & #2 I designed them and the foundry that I was going to use stole my patterns and sold them to Scott Drake, who is now manufacturing them. I still have the original wood patterns with a post mark date to prove it, but thats a long story. Anywhoo, they are a lot easier than the way I went and they are a lot more sturdy than drilling and putting a pin or bolt in the hinge.
Thu Mar 15, 2012 11:16 am |
[ 6 posts ] |
