www.ColoradoClassicBroncos.com - View topic - Measurements needed
It is currently Sun Nov 17, 2024 11:46 am
Reply to topic  [ 7 posts ]
 Measurements needed
Post Measurements needed
I need a couple of measurements before I start welding in my floor pans. Can someone please measure from the seam where the driver's side floor pan meets the tunnel to the body mount bolt and from the tunnel to the kick panel across the top of the bolt? I want to make sure I'm taking out as much of the existing tweak as possible and PO of my truck hacked up the floor pans pretty good. I also think the floor pan I got is stamped for the body mount hole about 1/2" off and I want to verify before I call the vendor and talk to them about it.
Thu Mar 01, 2012 12:16 am
Post Re: Measurements needed
Bump. I'm hoping to weld a patch into the kick panel and really don't want to screw up the alignment of the door post. Any chance someone can measure the width of the driver's side floor pan along the front seam where it meets the panel that is underneath the pedals (lower firewall, I think)? Basically, the width of the floor pan from the seam where it meets the transmission tunnel to the door post/kick panel?
Tue Mar 13, 2012 11:10 pm
I can tomorrow morning for sure. I have the entire interior out of the truck.
Tue Mar 13, 2012 11:48 pm
I'm getting 11 1/8" and 20 3/8", but don't take those for gospel. My tunnel is pretty close to stock on that location, but my body I am sure is tweaked. I don't think they are 1/2" off, but 1/8" tolerance should be about right.
Wed Mar 14, 2012 8:16 am
Heres mine
Wed Mar 14, 2012 10:45 am
One more
Wed Mar 14, 2012 10:46 am
Awesome, thanks guys.
Wed Mar 14, 2012 10:47 am
32,891,403 Views Powered by phpBB © 2000, 2002, 2005, 2007 phpBB Group.
