www.ColoradoClassicBroncos.com - View topic - C bushings
It is currently Sun Sep 29, 2024 9:32 am
Reply to topic  [ 9 posts ]
 C bushings
Post C bushings
It just occurred to me when I was going through my garage for the swap meet that I never installed my new C bushings with my lift kit. just starting them tonight and the bolts won't brake loose. Any helpful hints on this. Is this something that should have been done first with the lift? Now I have settled for beer and lots of it. If anyone wants to come over I have more beer.
What did you learn?
Wed Mar 14, 2012 6:57 pm
Post C bushings
Impact tools. Or a big ratchet and a BFH. You will need to drop the axle, remove both shocks, coil springs, and cups.
Wed Mar 14, 2012 7:14 pm
Post Re: C bushings
Thats what I thought. Thank you. banghead
What did you learn?
Wed Mar 14, 2012 7:24 pm
Post C bushings
FYI.....you need to be very precise when you install the bushings and bolt everything back up....if the arms aren't dead even, you WILL have Bronco lean to one side.
There is a tech article on the WH web site that describes the process in detail. I'll go find it....
Wed Mar 14, 2012 8:12 pm
Post C bushings
http://www.wildhorses4x4.com/product/br ... n/tech_faq
Wed Mar 14, 2012 8:14 pm
Post Re: C bushings
soak all the ends of the bolts with a good penetrating oil. PB blaster works pretty good if you can stand the smell. Soak them 2-3 times a day, then impact or big breaker bar. Make sure you watch your knuckles and that the tool is under warranty.
Thu Mar 15, 2012 8:25 am
Post C bushings
If you drop the axle much, you'll want to disconnect the breather line as well as the brake lines.
Thu Mar 15, 2012 12:39 pm
Post C bushings
Lila, I'm back in town and not too far down the road from you, plus I have a few days off for post deployment R&R, so let me know if you'd like some help or need tools.
Thu Mar 15, 2012 2:15 pm
Post Re: C bushings
sounds good. Thank you! I will probably tackle this next week when I'm off again.
What did you learn?
Thu Mar 15, 2012 5:44 pm
32,379,705 Views Powered by phpBB © 2000, 2002, 2005, 2007 phpBB Group.
