www.ColoradoClassicBroncos.com - View topic - Gear and locker install directions
It is currently Sat Sep 28, 2024 11:17 pm
Reply to topic  [ 3 posts ]
Post Gear and locker install directions
I'm getting closer to buying gears and lockers for my 60s in the EB. Going 538s with an eaton elocker in front and welded in rear. Question is are ther any good books or articles on how to do this and what special tools are required. I have removed and put in lockers and gears before but never did a fresh install.
Thanks
Chaser.
Wed Mar 21, 2012 7:07 am
Post Re: Gear and locker install directions
We have some gear install experts on this board, so they may add to my small list of special tools.
Dial indicator to measure backlash
A hone to make the ID of your current bearings larger so they slide on and off with ease. You use them only to set the gear set up and then press your new ones on just before final assembly.
Patterning grease (may be part of your kit already)
I'm not aware of any articles, but:
http://lmgtfy.com/?q=Setting+up+gears+for+a+Dana+60 bangtard
Wed Mar 21, 2012 7:57 am
As Jesus_Man said Dial Indicator and Hone.
I would also add
-access to the oven to heat the gears up
-a separator to pull apart the yoke when trying to set pinion depth
-inch lb torque wrench
I pulled a good write up off the net for a ford 9 and 44. I can see if I still have them and get you the links.
66 1/2 Cab Rock Toy
68 Mall Crawler (someday)
Thu Mar 22, 2012 11:39 am
32,369,894 Views Powered by phpBB © 2000, 2002, 2005, 2007 phpBB Group.
