It is currently Sat Nov 23, 2024 7:32 pm
airbur
Tue Mar 20, 2012 11:32 am |
I like the adjustable RS9000's on the back so much I decided to pick some up for the front today.
Tue Mar 20, 2012 9:53 pm |
Finally got my front bumper done! Still have to bolt the winch on. Also installed new my new front fenders. Still a bit to go but it is coming along.
Sat Mar 24, 2012 5:49 pm |
99f250
Awesome bumper!
Sat Mar 24, 2012 8:44 pm |
99f250
Got the wild horses roll cage handles put on...disc brake kit should be here Monday
Sat Mar 24, 2012 8:45 pm |
Replaced pass side D44 axle. Note to self: stay out of Bronco sized mud holes.
Sun Mar 25, 2012 8:29 am |
rdanford
Joined: Wed Sep 29, 2010 8:12 pm Posts: 169 Location: Windsor
Got the rebuilt 3rd with 4.10s and rebuilt axles installed...wow, the new power is great
_________________ Royce 1977 Bronco...EFI, ViperBuilt C4, PS, PB, cut with 33's - Rebuild coming 1987 Porsche 951...LS1 swap - SOLD 2006 4Runner V8 Sport Edition 1998 4Runner...DD with 333k and counting
Sun Mar 25, 2012 8:42 am |
TIM
Joined: Sun Nov 07, 2010 9:54 pm Posts: 41 Location: Denver
for the past 3 weeks i've been working on replacing driver side kick panel, inner rocker, door post, rocker, fender, inner fender, floor panels.. and today I FINALLY got the doors alligned right (almost perfect) so now I can take out the self tapping screws and spot weld it all together... I'll be showing up to meet in a bronco by mid summer for sure.
Sun Mar 25, 2012 2:50 pm |
airbur
Sun Mar 25, 2012 4:47 pm |
Tue Mar 27, 2012 1:39 pm |
Dan, remind me what pump setup you have. Is it a BC in-tank pump?
Tue Mar 27, 2012 3:10 pm |
Id build a heat shield before goingthrough the hassle of moving the lines. My carb doesn't vapor lock....
Tue Mar 27, 2012 4:43 pm |
Which rear lunchbox locker did you guys do?
Wed Mar 28, 2012 11:12 am |
Powertrax No-Slip, picked it up from Off Road Ltd (they had a great price w/ mil discount), originally wanted to drop it into my old carrier but ran into a bearing size prob, hence a complete build.
Wed Mar 28, 2012 10:48 pm |
In between checking EFI codes, I fixed my horn. Had to put new aluminum tape behind the horn button on my Grant steering wheel. 14 years, and multiple disassemblies & reassemblies had damaged the contact surface. Still pretty wimpy, but at least it works. I need a real horn, like Zilla's.
Wed Mar 28, 2012 11:37 pm |
Zilla, I wish I knew you were keeping cooper. I have a little, and I mean a little here, so it's not worth it to me to take to the scrap yard. It's a U-shape from a defunct indoor fountain.
Be happy to give it to anyone.
Thu Mar 29, 2012 7:14 am |
Thu Mar 29, 2012 7:25 am |
airbur
Started hearing a clunk every time I shut the driver's door. Cracked it open and found this....metal mounts both cracked off....
Sat Mar 31, 2012 5:18 pm |
Airbur, that looks very familiar.
Last night, I finally had enough confidence in my Bronco to drive it out to my friend's shop and have my tires swapped onto my "new" rims. Changed from Centerline HTIIs 15x10, to refurbed & repainted steel 15x8. Didn't go black, seems to be done a lot today, but went with a gray close to Audi bumpers. The new rims made the overall width a couple inches narrower, that is a good thing, since swapping to f/w axles, I felt like 1/2 the tire was hanging outside the flares. Still will end up with the wide flares from WH soon. The overhang sprays the side & inside of the truck with mud, snow, etc too much. Sorry the pics aren't great, by the time I took them the sun was setting and made it hard to get a good shot.
And she got a bath today. Since I have a facility dedicated to washing cars @ Avis, hopefully my fleet will stay cleaner.
Sat Mar 31, 2012 6:15 pm |
13 hour road trip to pick up Meyer snow plow which was supposed to be 6' but magically grew to 7' by the time we got there
Thanks Mike for doing the driving !
Sat Mar 31, 2012 7:10 pm |
Installed new header gasket on drivers side. It blew the whole back cylinder gasket out the last wheeling trip. Then washed it to get 3 wheeling trips worth of mud off.
My youngest grandson asked to go for a ride in papa's Bronco without the top. He saw a Jeep this past week with the top down and told his mama that he wanted to ride like that in papa's Bronco. So needless to say I removed all 3 windows and left it safari style. He came over and saw it and asked if we could put it down. Rob told him he'd get sunburned if we did so he was content. I had to put the back seat back in so me and him, daddy and sister could go for a ride. Took him to Jax so he could get a new pair of shoes. Watched him sitting in the back seat with a grin ear to ear the whole time. He and sister both had a ball.
Sat Mar 31, 2012 8:42 pm |
Gunni - the rims look great.
Sat Mar 31, 2012 11:51 pm |
D&D72
Sun Apr 01, 2012 12:43 am |
Sun Apr 01, 2012 3:42 am |
Gregg
I swapped out my old tranny cooler for a 96 explorer cooler. The old one was mounted on the underside of the radiator but i moved the newer one up in front. I'm not sure how I will notice any difference (other than not smashing it on a trail).
I also pulled the rear axles and dropped the third member. I'll be taking it to that dude in Erie and he'll build me a 4 pinion Limited slip. While he's working on that I'll be putting in new seals, picking up my sissy pink coffee cup (and asking Dan to press on some axle bearings), pulling and putting in new axle seals, wheel cylinders and rebuild the drums.
cool.
Update: I soldered the radiator tube from the tranny cooler mishap. works good so far but really wont test it until the center / axle / drums, are back together.
Sun Apr 01, 2012 9:01 am |
Wow, huge upgrade. Your rear end will be in great shape after all that...
Sun Apr 01, 2012 10:11 am |
I had a great weekend. I added carpet kit (thanks Landshark), insulation, roll bar dome light, fastened my interior panels (thanks JGZ), wired CB antenna, fire extinguisher.
Mon Apr 02, 2012 11:49 am |
Cool! Looks good Chad. Is that dome light hard wired or battery operated?
Mon Apr 02, 2012 12:13 pm |
It is battery powered with 5-bright LED lights and run on 3 AAA Batteries from Rampage on Amazon.com for $15.00 - 60 second install. Even has a magnet if ya wanna stick it instead of the roll bar mount. http://www.amazon.com/gp/product/B0046K ... 00_details
Mon Apr 02, 2012 12:22 pm |
Looks really good! Not to be the safety nazi (again), but how much clearance is there between the extinguisher and the rear seat occupant? It looks like it could rotate around the bar and smack that passenger in the head in a high speed impact.
Mon Apr 02, 2012 5:10 pm |
