[phpBB Debug] PHP Warning: in file [ROOT]/includes/bbcode.php on line 379: preg_replace(): The /e modifier is no longer supported, use preg_replace_callback instead
www.ColoradoClassicBroncos.com - View topic - Badlands 66
It is currently Sat Sep 28, 2024 3:30 pm
Reply to topic  [ 109 posts ]  Go to page Previous  1, 2, 3, 4  Next
 Badlands 66
Post Re: Badlands 66
Rob, you are awesome!
Tue Apr 10, 2012 8:35 pm
Woooooooooooo!!!!!!!!!!! Hooooooooooo!!!!!!!!!
fire fire boardin icon biggin :beer: foshizzle
Tue Apr 10, 2012 8:37 pm
Profile YIM
Nice job man! Now on to the fun stuff.
Tue Apr 10, 2012 9:11 pm
Just a little update. trouble shooting the idle issue now with howell. It either hunts real bad and stalls or idles at 1400rpm. So with their help hope to have that figued out. The starter went out saturday. Had to pick up a new one and got that put in. I think I have all the leaks fixed except for one. The trans linkage leaks.
Mon Apr 16, 2012 6:37 pm
Finally got a hold of howell. Need to get my sideband installed and get a number off the cal prom and get that info to them for a new cal prom. It wont idle because it seems to be running way lean.
Thu Apr 19, 2012 7:22 am
It's all in the fuel pressure. Once I ppinched off the return line to raise the pressure at the injectors the hunting idle stopped and it runs. Now to pull the throttle body off and try to make a permanant adjustment. Also need to find a different fan. This one is too deep. Does not pull air through the radiator.
Sun Apr 22, 2012 12:54 pm
Atta baby! icon biggin
Sun Apr 22, 2012 1:45 pm
Profile YIM
Sun Apr 22, 2012 2:56 pm
The other fan is the same way. Also got a fuel pressure gauge to put in the line to check it.
Sun Apr 22, 2012 3:31 pm
Sun Apr 22, 2012 3:49 pm
Profile YIM
Steve was itchin to burn rubber at breakfast
so near the finish line !
Sun Apr 22, 2012 7:06 pm
After running all the tests that howell suggested they are sending a new ecu cal prom. Should be here in a few days.
Wed Apr 25, 2012 7:18 am
Haha yea probably. Waiting for the new cal prom to show up. Plus I leave tomorrow for a week on vacation.
Fri Apr 27, 2012 6:21 am
Fri Apr 27, 2012 7:07 am
No extended vacation. The parts should be here when I get back so you have till next weekend to get yours running and driving. If that cal prom works then ill be deriving it next weekend.
Fri Apr 27, 2012 7:27 am
IT DRIVES!!!!!!
Video coming soon. :burnout:
Fri May 04, 2012 9:58 am
Woo hoo!!
Fri May 04, 2012 10:43 am
Profile YIM
No big burn out yet. Just a little one backing in the garage. Want to get miles on it first.
Fri May 04, 2012 11:14 am
I would if it was mine. I don't know how this motor was built.
Fri May 04, 2012 11:18 am
Crappy quality but its proof.
Fri May 04, 2012 11:43 am
Fri May 04, 2012 12:54 pm
Rob, that camera clipped to your hat?
Sure sounds nice!
Fri May 04, 2012 1:14 pm
Trying to hold my phone and drive.
Fri May 04, 2012 3:07 pm
Fri May 04, 2012 9:17 pm
Profile YIM
Sat May 05, 2012 7:24 am
Great job!!
Is the video of the burn out real? For us new folks, is it really a Pontiac engine?
An all wheels burn out is called for!
Terry
Fri May 11, 2012 5:33 pm
Fri May 11, 2012 5:47 pm
Profile YIM
Got the gauges working now it has water temp. Got it running pretty darn good. Installed a new alternator so now it charges. Need to hook up the kick down cable and it's time to put some miles on her. Hope the weather holds out saturday so I can go for a spin for more than around my neighborhood. Looking to drop it off next week for new exhaust.
Fri May 11, 2012 7:11 pm
Got most of the bugs worked out. Put 5 miles on it yesterday. Ran it to the gas station and filled it up. 80$ freaking bucks. Plan to drive it today. Gonna have to tear down the front suspension. Needs to have the caster measured and fixed. It wanders really bad. Steering doesn't return to center while driving. Kinda a scary to drive.
Sun May 13, 2012 7:17 am
32,365,478 Views Powered by phpBB © 2000, 2002, 2005, 2007 phpBB Group.
