www.ColoradoClassicBroncos.com - View topic - Hub/Drum seperation
It is currently Sat Nov 02, 2024 4:24 am
Reply to topic  [ 9 posts ]
 Hub/Drum seperation
Post Hub/Drum seperation
Anyone know of a sure fire technique for separating the drum from a hub, aside from going out and buying a press? I really don't feel like paying one of the local shops $89 an hour!!!! when I can spend that much on a press from Harbor Freight. And I really don't feel like going down to HF, buying the press, setting it up and only using it once a decade.
I was thinking BFH and a block of wood but I dunno. Then my problem becomes marrying up the new drum and hub. Guess I'm gonna have to suck it up and drop the coin unless someone has a trick up their sleeve.
Wed Dec 08, 2010 7:43 pm
Post Re: Hub/Drum seperation
Knock the studs out with a BFH.
Wed Dec 08, 2010 7:45 pm
So, once the studs are out the drum should separate easily from the hub?
Wed Dec 08, 2010 7:50 pm
Don and Dan,
appreciate the offers. I'm hoping to get these back on before Saturday though. Pretty much leaves me with tonight and maybe tomorrow night, depending on the wife's work situation. I generally avoid wrenching when she is off of work, in order to maintain rapport at home and not sour her to Bronco-madness.
Don, your technique sounds familiar and I think I might have done something similar on the '66 about 10 years ago in my backyard in NC. It's just been awhile. I know I certainly didn't use the brass drift then, but I will be sure to this time.
Thu Dec 09, 2010 1:27 pm
Applying a little heat with a propane torch will help too.
Thu Dec 09, 2010 7:39 pm
Done and done. BFH plus rage= no need for a press.
Thu Dec 09, 2010 8:24 pm
I'm a huge fan of a little heat, needed quite a bit to get that toasted bearing out of the housing the other day.
Thu Dec 09, 2010 8:54 pm
Thu Dec 09, 2010 8:56 pm
Lucky for me the only thing I have had to use heat on to date was the tracbar and leaf spring bushings. Of course, that was less heat and more FIRE!!!
Thu Dec 09, 2010 9:30 pm
32,752,710 Views Powered by phpBB © 2000, 2002, 2005, 2007 phpBB Group.
