Register •
FAQ
• Login
It is currently Fri Sep 20, 2024 7:43 am
[ 3 posts ] |
Re: Tie-Dows 101
Yeah, I've seen some scary stuff and done some of them myself.
My preference is 4 points that compress the suspension.
Wed May 09, 2012 8:01 am |
Re: Tie-Dows 101
I experienced that extra thump when the body roll hits on a trailer. A corner snuck up on me and was going too fast. It was bad enough when all the weight transferred, but I nearly lost it when the body roll hit. Since then it's been compress the suspension.
Wed May 09, 2012 8:41 am |
Re: Tie-Dows 101
Sat May 12, 2012 8:58 pm |
[ 3 posts ] |
