It is currently Fri Sep 20, 2024 3:59 am
[ 14 posts ] |
4 Kinds of heads, which one to run...
Sun May 13, 2012 1:11 pm |
airbur
Re: 4 Kinds of heads, which one to run...
From your list..I would stick with the 351 heads you have...just get them cleaned up and rebuilt.
Sun May 13, 2012 1:59 pm |
Colorado75bronc
Ya the 351 heads would be best, the e6se's are junk --- I am here: http://tapatalk.com/map.php?nd1rbv
Sun May 13, 2012 3:07 pm |
Just for my own edjemeckation, what is the difference between the various heads? I'm guessing the 351w heads flow better, but why, and why are the e6se's junk?
Sun May 13, 2012 6:26 pm |
Colorado75bronc
They have small valves and a large bump In the exhaust port, flow poorly and are a smog head --- I am here: http://tapatalk.com/map.php?xgnyts
Sun May 13, 2012 6:40 pm |
Colorado75bronc
The valves aren't any smaller than the others sorry bout that, but with the 64cc chamber they'll lower the compression= less power, the e7te's are decent about the only benefit of them over the early 351w heads is the valves should be plated valves in the e7te's, less prone to wear than the early stuff --- I am here: http://tapatalk.com/map.php?lt0let
Sun May 13, 2012 6:46 pm |
if the e6's have been plained that should bring down the chamber size correct? I guess i should measure what size cc they actually are... i dont think they are stock anymore..
Sun May 13, 2012 9:41 pm |
E7's are the best ones listed. I don't think the mid 70's 351w heads are any different than 302 heads other than the head bolt hole size.
Sun May 13, 2012 10:28 pm |
Mon May 14, 2012 6:49 am |
66Crawler
Joined: Fri Jan 27, 2012 4:41 pm Posts: 92 Location: Longmont, CO
e7's would be my 1st choice. 351's if the e7s cant be cleaned up.
_________________ 66 1/2 Cab Rock Toy 68 Mall Crawler (someday)
Wed May 16, 2012 12:46 pm |
Shawns Fords
I would go with the E7's as well, a very common head.
Wed May 16, 2012 7:08 pm |
Thu May 17, 2012 6:38 am |
Colorado75bronc
Thu May 17, 2012 9:22 am |
Shawns Fords
FORD = For The RoadheaD!
Thu May 17, 2012 11:37 pm |
[ 14 posts ] |
