It is currently Sat Nov 23, 2024 5:07 pm
airbur
Good question....this is my first pull! Maybe someone else can chime in. I do see how once I get it up a few inches, you can use the lever to level out the load so its all in better balance.
Thu May 24, 2012 2:59 am |
I've watched "Car Warriors" and it seems those levelers are the cat's meow! I want to incorporate one into my hard top hoist so I can level it...
Thu May 24, 2012 7:30 am |
airbur
I'll let you guys know how it goes on Sunday when I pull it. I raised it up a few inches yesterday to verify everything was free.
Thu May 24, 2012 7:36 am |
I have used it forever and love them.
They are especially useful is you are pulling a motor with the tranny still on it as you can change the angle of the load as needed throughout the process.
Thu May 24, 2012 7:44 am |
Thu May 24, 2012 11:19 am |
Thu May 24, 2012 11:36 am |
Got the new Chomo's in last night and put it all back together. Haven't driven it in a few weeks, but I couldn't resist. The new steering shaft really tightened up the steering! Great control now!! I didn't put diff oil in yet, so I left it in 2WD, but I'll get that done over the weekend and test the locker! I think I am ready for Moab. Some "want to do's", but we'll see how they play out.
Fri May 25, 2012 7:32 am |
airbur
Cake.....by myself even:) Come and get her socofn.
Sun May 27, 2012 6:40 am |
socofn
Be there this afternoon. JP
Sun May 27, 2012 7:44 am |
airbur
Socofn and son picked up the engine/ tranny today. I raised the engine up and he backed the truck right under it and I let her down. Worked like a charm! Thanks to Rox for the use of his hoist.
Sun May 27, 2012 9:41 pm |
Easy Peasy Airbur! I saw a trick on that Car Warriors show a while back. If you want to get the jack way up, put your should under the lifting arm, loosen the bleeder and push up. Sure beats jacking it up little by little!
I filled the front diff with oil. That's really all I got to do.
Tue May 29, 2012 7:48 am |
airbur
Yea...I actually was able to just use my hand and push it up.
I started removing stuff from the firewall and the engine bay in general. Master cylinder, battery, wiring harness, lower steering shaft, wiper fluid res., etc. 76FordBronco stopped by and picked up the bikini top.
Tue May 29, 2012 7:51 am |
socofn
I managed to get the old engine out. I should have know that once you start something on these old trucks you find numerous things you want to do. I ordered a twin stick kit last night!! I am going to pull everything from the engine bay and power wash it and then repaint. The whole "since I am there" syndrome could get expensive. JP
Tue May 29, 2012 11:50 am |
Tue May 29, 2012 11:51 am |
Badlands
Put in the dash pad. Steel brushed and sanded out a bit of rust and loose bed liner out of the back. Sprayed a $10 can of Dupli-Color Truck Bedliner down as a temporary patch and rust stop until I get really ambitious and get it all taken out and redone. Hope to insulate/sound proof the cab floor and firewall this week and get the carpet installed.
Sun Jun 03, 2012 9:53 am |
socofn
Been scraping and cleaning the engine bay up getting ready for paint. Today i cleaned up the T case and put new gaskets in. Hope to have it all ready to go back together and running by June 15. WHAT A PROJECT!!!
Sun Jun 03, 2012 8:52 pm |
Badlands
Lined the cab with some hvac self adhesive heat shield/insulation and installed the carpet. Should keep the heat down and quiet things up some, seemed to anyway!
Wed Jun 06, 2012 7:06 pm |
cracker
Joined: Mon Oct 04, 2010 9:19 am Posts: 113 Location: pueblo
Finished repairs after Montrose.... New fan, front U-joints and upper/lower ball joints on the left side. Regreased the driveshafts and checked fluids.... Now ready for Penrose tomorrow..
_________________ 1-1966 Bronco 1-1967 Bronco 1-1969 Bronco 2-1973 Broncos And a couple even run.....
Fri Jun 08, 2012 3:41 pm |
dropped my engine block off to get re-bored .40 over and get mated up with my new heads.. started to rebuild the door hinges.. i actually got the pins out!
Fri Jun 08, 2012 3:45 pm |
4 turn steering box swap, installed WH track bar riser, lower u joint in the steering rod. Now it's amazing, of course when you update things the next item is always in line... now I notice how loose my steering column and wheel are!
Fri Jun 08, 2012 6:36 pm |
Took it off my son's truck and into the back yard (dont tell the HOA) while I finish up a friends 67 mustang so I have room for it in my garage! Oh yeah - Mustang Sally will be heading home soon.... real soon.
Sun Jun 10, 2012 7:40 am |
Sun Jun 10, 2012 8:18 am |
sbolt19
Well yesterday, I replaced the fuel pump on my ride. I was down at Don's junkyard and got over to my Dad's house and the fuel pump took at crap on me. I was going to originally swap out PS pumps with a saganaw dual inlet, but the fuel pump went out so I did that instead. I'll do the PS pump sometime this week, just pisses me off that the other one went out.
Mon Jun 11, 2012 9:01 am |
Mon Jun 11, 2012 9:54 am |
sbolt19
Mon Jun 11, 2012 11:13 am |
Why don't you buy a brand new Bronco complete switch and just wire the Centech stuff in to it? Or is it already set up that way?
Mon Jun 11, 2012 12:35 pm |
The Centech kit comes with its own ignition switch. To use the Bronco switch, you have to use their adapter.
sbolt, I have a Centech kit with its ignition switch. I plan on using my Bronco's switch, so I won't use the Centech ignition switch. If you want it let me know, I'll give it to you.
Mon Jun 11, 2012 1:15 pm |
sbolt19
Gunni, the Centech switch is a 1970 Jeep CJ-5 switch. I called them and asked what it was and the guy was real pissed when I told him what happened. He got pretty crappy with me and I figured that I had nothing to lose so I told him that the switch they used was not a good fit, nor did it hold up that well and it should be better engineered. Didn't get me far but it made me feel better. But sure, if you aren't gonna use it, I'll take it, because the replacement that I got from CSK is a POS. I might have to break down and buy a new EB switch and get the adapter like you are doing.
Mon Jun 11, 2012 3:29 pm |
Mon Jun 11, 2012 5:08 pm |
Badlands
Getting a speaker/center counsel box fabbed with my stepson for in front of the bench seat. Took my granddaughters to see Madagascar 3 in the "coolest car in the whole world".
Mon Jun 11, 2012 5:26 pm |
