www.ColoradoClassicBroncos.com - View topic - Tips & Tricks
It is currently Fri Nov 22, 2024 11:32 am
Reply to topic  [ 16 posts ]
 Tips & Tricks
Post Tips & Tricks
Thought it would be good to start a thread on "'Tips and Tricks"....
I know it is great when someone gives me the "easy" way to do something, so thought with all this knowledge around maybe we could start a thread.
Could be anything from as easy as "bring a tarp along to throw down when you are going to have to work on the truck in the muck". Yup...carry one all the time now and have one for the driveway!
Post up and tell us how to do it easier!!!!
Matt
Sat Dec 11, 2010 8:41 pm
Post Re: Tips & Tricks
Good idea. Here's one that I use.
For anyone running a carb off road should have the spring loaded needle and seats. Also a trick I use is put a fuel pressure regulator in. And when going wheelin turn it down to 2psi or so. Just DONT forget to turn the pressure back up before hitting the road or you'll run it lean. The lower fuel pressure keeps the carb from flooding when the floats are bouncing.
Sat Dec 11, 2010 8:44 pm
Bring ViperWolf.
Mon Dec 13, 2010 9:23 pm
This is applicable to almost everything. Before you take something apart take digital pictures. When you're taking it apart bag/label the parts. Take more pictures. When you have an assembly taken apart put the bolts/screws back in there original holes if possible so you so you know where they all are and where they go.
Mon Dec 13, 2010 9:48 pm
When checking electrical issues - Check the ground first. I have lost count of the times I have chased all over a vehicle looking for a short, bad switch or relay, only to find a loose or broken ground.
Tue Dec 14, 2010 7:57 am
Tue Dec 14, 2010 12:42 pm
Tue Dec 14, 2010 8:01 pm
here's a couple, i know more but this came to mind first, if you run a holley set your float levels low, to where your have to rock the truck to get the fuel to slosh out of the sight hole, this helps drastically with offroad performance, you can also make a cross-over vent tube and install a vent whistle, but those other mods are a little more in depth, classicbroncos.com has a write up on holley carb offroad tips/tricks, and so far i've been far more impressed with my properly setup holley offroad than any of the multiple edelbrocks i've had over the years, although i haven't thoroughly put it thorough its paces, ive been over some pretty good hills, and thorough some rough ditches and ruts that it used to complain on with the edelbrock, i just gotta get it in the rocks now, but i still can't wait till i have all the stuff for efi
if installing a body lift and you don't have access to a shop lift, set e-brake and chock the wheels, loosen one whole side of the body a couple turns on each bolt, remove all the bolts from the other side, and use a 2x4 or 4x4 thats as long as your rocker panel or close to and a highlift jack, 2 preferably for safety, but you can with one, complete the body lift on that side of the truck, tighten the completed side down snug, repeat on the other side, also air hammers/air chisels make easy work of removing stubborn old bodymounts
Tue Dec 14, 2010 9:22 pm
Tue Dec 14, 2010 10:47 pm
Sun Jan 30, 2011 6:06 pm
Learned a new one with my recent tranny install. When bleeding your slave cylinder, you should bleed it by normal means, but if you're not getting the pedal feel you want, there should be an inspection port on the tranny near the bell housing. Stick a pri-bar in there and manually push the slave cylinder back slowly to get rid of the stubborn bubbles. I did this once with a little improvement, but would like to try again.
Mon Jan 31, 2011 10:12 am
As I just had the front bearing almost weld itself to the shaft....
Found a clamp type device from harbor freight (anyone is more than welcome to borrow) and then borrowed a 2 jaw puller from Autozone to get it off. Put a 3/16" plate over the end of the axle for a jacking point. Worked like a charm with a good 1/2" drive.
Matt
Mon Jan 31, 2011 7:25 pm
For your carb'ed guys - my dad (a diesel mechanic) told me to run a gallon of diesel in with the gas to help prevent vapor lock. Diesel has a higher boiling point so the mixture seems to give you a few more degrees before the fuel with turn to a gas.
Tue Feb 01, 2011 10:03 am
Tue Feb 01, 2011 7:22 pm
...always carry a spill kit on the trail. Leaks on the trail are not uncommon, and preventing damage to the enviroment will help to keep the trails open.
Mon Feb 14, 2011 6:03 pm
id say carry food, tools, water, jumper cables etc inside ur car. i do at all times.
Mon Feb 28, 2011 5:09 pm
Users browsing this forum: No registered users and 26 guests
32,949,143 Views Powered by phpBB © 2000, 2002, 2005, 2007 phpBB Group.
