Postby ZOSO » Mon Jun 11, 2012 4:28 pm
Badlands wrote:Getting a speaker/center counsel box fabbed with my stepson for in front of the bench seat.
Took my granddaughters to see Madagascar 3 in the "coolest car in the whole world".
icon biggin
Glad you are enjoying it.
Postby sbolt19 » Tue Jun 12, 2012 8:50 am
Gunnibronco wrote:Is your address in the member's list a good mailing address, I'll send it USPS tomorrow.
Sure is, and much appreciated, I owe you one, for sure. :beer:
sbolt19
Postby Gunnibronco » Wed Jun 27, 2012 2:42 pm
Brought this home:
Now to wire & plumb it.
Postby crawlercreations » Tue Jul 03, 2012 5:50 pm
Fixed/modified my taillights today. I had a broken one from my recent crawling trip so instead of sticking another 66 taillight lense on it to break eventually I made my own. Definitely not for everyone, but it works for me.
Off
Running lights
Brake/turn/hazards
Postby ZOSO » Sat Jul 07, 2012 3:49 pm
Brought it home. Tucked it away in my own garage. Bet my parents are happy its no longer in their back yard. Got the whole front clip loose crept one screw on the drivers door jam. Gonna have to cut it off. Also turned the motor over by hand. It turns smoothly. Can't wait to get goin on this.
Postby Colorado75bronc » Sat Jul 07, 2012 5:37 pm
Finally got the new leaf spring perches from ruff stuff last night, got the d60 centered, pinion angle set, and welded the perches on after bolting it all back together, driveshaft doesn't need lengthening or to be shortened, I guess 3 1/2 inches was the perfect amount to push the rear d60 back, drove it around the block as I haven't driven it in months, runs good with the 410's, just need to find a reamer so I can get the tierod to pull up a lil more into the knuckles
Colorado75bronc
Postby ZOSO » Sat Jul 07, 2012 6:33 pm
Chevy tre's? I have a reamer you came borrow. I'm goin to pueblo Tuesday through Thursday. I can throw it in if ya can't find one down there.
Postby Colorado75bronc » Sat Jul 07, 2012 6:50 pm
No just stock 79 bronco for now, the 76 Dana 44 flat top knuckles I got have use a smaller tre, but I think it's the same taper as Chevy one ton, I'll let ya know, I might have a line on one Monday
Colorado75bronc
Postby landshark » Sat Jul 07, 2012 11:01 pm
Should be the same taper 1.5 per foot or something
Postby Colorado75bronc » Sat Jul 07, 2012 11:50 pm
Or 7 1/2 degrees I think
Colorado75bronc
Postby landshark » Sun Jul 08, 2012 4:35 pm
Colorado75bronc wrote:Or 7 1/2 degrees I think
ya thats it.. 7.5 degree per foot or something or other ;)
I cleaned and painted the MC, Brake booster, bracket and hardware today.. only a few more things to clean up and paint before the chassis gets here...
Postby Viperwolf1 » Sun Jul 08, 2012 5:11 pm
How many degrees per inch is that?
Postby landshark » Sun Jul 08, 2012 7:49 pm
1-1/2" per foot
7.5 degree?
that should be correct i think.. i have one and dont even remember
Postby Colorado75bronc » Sun Jul 08, 2012 9:39 pm
That sounds like it
Colorado75bronc
Postby Colorado75bronc » Tue Jul 10, 2012 8:46 am
ZOSO wrote:Chevy tre's? I have a reamer you came borrow. I'm goin to pueblo Tuesday through Thursday. I can throw it in if ya can't find one down there.
If you haven't headed down towards the springs yet would you mind bringing that reamer
Colorado75bronc
Postby ZOSO » Tue Jul 10, 2012 8:25 pm
story man when you called I was on the phone at work. I was already in pueblo by then. I didn't throw it in being I had a day from hell on Monday.
Postby Colorado75bronc » Tue Jul 10, 2012 10:01 pm
No problem man, are you coming down any other time soon?
Colorado75bronc
Postby kchaser » Thu Jul 12, 2012 8:00 pm
Took it fishin
kchaser
Postby ZOSO » Thu Jul 12, 2012 8:08 pm
cutting. lots of cutting. making some patches for the rusted out cowl.
Postby airbur » Thu Jul 12, 2012 8:14 pm
Picked up my hybrid T/J Viperized D20 today:). Amazing work!
airbur
Postby Rox Crusher » Thu Jul 12, 2012 8:16 pm
airbur wrote:Picked up my hybrid T/J Viperized D20 today:). Amazing work!
as usual, that thing looks awesome !
Postby sbolt19 » Fri Jul 13, 2012 8:05 am
What is involved with the hybrid? Is it geared lower than the EB D20?
sbolt19
Postby Viperwolf1 » Fri Jul 13, 2012 9:48 am
It's just the 2.46 T gears combined with the J shift rails and J front output shaft. All the best parts from the Dana factory.
Postby airbur » Sat Jul 14, 2012 4:59 pm
Decided to see how a power washing would do on the engine bay. It did ok...not great.
Removed the power steering gear and used Aircraft Remover to get rid of the nasty red paint I previously used on it. Going to ship it along with the Explorer pump out to Lee's Power Steering shop for complete rebuilds. They can increase the flow of the pump also and build the hoses I need.
airbur
Postby akaFrankCastle » Sat Jul 14, 2012 10:04 pm
Decided I didn't have enough ankle biter issues with the Bronco, so tonight I went ahead and snapped off an intake manifold bolt. I was bored and the gasket R&R was going too well. Haven't figured out whether the reused Mr. Gasket intake bolts or the Harbor Freight torque wrench get credit for the assist.
Postby Justin » Sun Jul 22, 2012 10:52 pm
Finally got some time to work on it. Needed to put another bend in the twin sticks to get them to clear the NP435 shifter, so I fired up the new-to-me oxy-acetylene setup for the first time.
Postby Gunnibronco » Sun Jul 22, 2012 10:59 pm
Justin wrote:Finally got some time to work on it. Needed to put another bend in the twin sticks to get them to clear the NP435 shifter, so I fired up the new-to-me oxy-acetylene setup for the first time.
fire fire
Postby Badlands » Sat Jul 28, 2012 1:44 pm
Nothing really......but 76, ZOSO, and booger came by this morning and got the new 7 degree bushings installed, Mike's front drive shaft hooked up and popped in a new chip in the computer. Appears to be running great, handles like a maserati, and is ready to climb Mt. Everest. I thought I did a nice job staying out of the way.
I want to also thank cobshane for fixing that flywheel making a racket after the bolts backed out.
I don't know what I would do without the great guys in this club. One thing I know I wouldn't be doing is driving my Bronco much.
Badlands
Postby Colorado75bronc » Sun Jul 29, 2012 10:17 am
Finally got the steering knuckles reamed, steering installed and got back to driving it last Wednesday, drives great, gotta save up and hopefully in 2-3 weeks can get the rear disc brake kit for the d60, drove it to my buddy's wedding, had to shuffle him around in it for pictures, the photographer was a bronco chick, she wanted to include mine in the photos, I told her probably best to do what the bride wanted haha
Colorado75bronc
Postby airbur » Wed Aug 01, 2012 5:29 pm
Raptor Liner arrived. Need to finish prepping and repairing the one rust spot.
airbur
Return to Chit Chat
