75DBE
Transfer Case Bolts
Anyone know off the top of their head what size bolts I need to mate up the transfer case to the end of the transmission?
Tue Sep 04, 2012 9:00 am |
Re: Transfer Case Bolts
Not sure, but consider using studs with nuts instead. The t-case is kind of the pain to align otherwise, especially if you're installing it solo.
Tue Sep 04, 2012 9:23 am |
75DBE
Really? Wow, I never thought of that. It is kind of a bear to wrestle around underneath the Bronco. Good idea, thanks!
Tue Sep 04, 2012 10:10 am |
Don't thank me, I stole it from Viper. Will be doing this to my rig after I rebuild my spare D20.
Tue Sep 04, 2012 11:12 am |
Now, I'll be doing something like that tonight or tomorrow. Thanks for the tip, just in time. It is not easy to balance that thing on a jack and get everything lined up, especially alone.
Tue Sep 04, 2012 11:59 am |
T-cases are difficult at best to install. Their center of gravity is just not conducive to wiggling it around without the proper equipment. SO anything you can do to help the process is money and time well spent. Wish I knew the size, but I do not.
Wed Sep 05, 2012 1:15 am |
jbregar
Joined: Thu Jun 07, 2012 10:10 pm Posts: 94 Location: Pueblo West, CO
Aren't they 3/8-16?
_________________ 1966 Bronco (Aug. 1965 production date), 5.0L Explorer EFI, 33x12.50 BFG AT
Wed Sep 05, 2012 1:35 pm |
75DBE
I will be checking tonight! I will let you guys know. Thanks!
Wed Sep 05, 2012 2:17 pm |
jbregar
I checked mine and they're certainly 3/8-16. I'm switching mine out for studs when I put the t-case back in.
Thu Sep 06, 2012 9:55 pm |
75DBE
Good to know sir -- thank you very much!
Thu Sep 06, 2012 10:33 pm |
