It is currently Mon Sep 23, 2024 3:16 am
[ 7 posts ] |
Pulling a van motor
As always, I LOVE to over think things. 45 days of planning for 45 minutes of work. Of course, it never works out to my benefit. There is always that one thing that goes wrong and completely throws a wrench in my accomplishing something in record time.
Anyhow, to the point. I'm about to pull a motor. It's in a van. Looking at it, it would seem there is not nearly enough room to fit it out the front without removing the grill and the core support. From the inside was my first inclination, but that seems impossible without first removing the transmission.
So, have you ever pulled a motor from a van? And how did you get that square peg out of that round hole?
Thu Dec 06, 2012 12:15 am |
Re: Pulling a van motor
Well.... Do you need the van to be usable when you're done? If not you have options, both include the use of a saws all and/or angle grinder. Cut the core support & firewall and pull it put the front or cut the floor and pull the engine & trans out via the door.
Thu Dec 06, 2012 6:03 am |
I do believe the "owner" of said vehicle would prefer minimal damage incurred during the removal, so as to continue to profit from parting out.
Thu Dec 06, 2012 8:35 am |
Okay be nice then, pop the trans, pull the dog house and unbolt the core support if able, bring shoe horns!
Thu Dec 06, 2012 10:05 am |
HIX
Joined: Tue Feb 15, 2011 12:38 pm Posts: 174 Location: Wheat Ridge Colorado
If you must leave the front parts in place your only real choice is to pull all the junk hanging on the block Upper intake, headers, front accessories. And the seats.Pull the driveshaft unbolt, slide the tranny back and down. And it will fit thru the doghouse with a twist
Thu Dec 06, 2012 12:17 pm |
Thanks guys. Looked a bit like shoving 15 pounds of crap into a 5 pound bag when I was having a look at it.
Thu Dec 06, 2012 7:35 pm |
Thu Dec 06, 2012 8:56 pm |
[ 7 posts ] |
Users browsing this forum: Google [Bot] and 1 guest |
