www.ColoradoClassicBroncos.com - View topic - Rubber Windshield Frame to Top Seal
It is currently Fri Nov 01, 2024 3:24 pm
Reply to topic  [ 5 posts ]
Post Rubber Windshield Frame to Top Seal
Ok, so I am tinkering with odds and ends. I wanted to put the bracket on the top of the windshield so that I can mount the soft / bikini top bracket. I thought that I ordered the correct rubber seal but it is so thick -- and has ribs front and back -- that maybe there is something else that I should have ordered?
Wed Jan 16, 2013 11:25 am
Post Re: Rubber Windshield Frame to Top Seal
I believe mine is a simple foamy piece about an inch wide, I think u could find it at a hardware store.
Wed Jan 16, 2013 2:47 pm
Yeah. I talked to WH and they said what I was thinking -- the thicker rubber seal is just for the hard top. I ordered the wrong thing. Crap! He said they just use the double sided sticky tale -- and sometimes not even that -- when they put the soft top riser on top of the windshield. Guess I can just save this piece if I ever decidfe to put the hard top back on.
Wed Jan 16, 2013 3:17 pm
I'd prefer rubber over foam just because the foam breaks down much faster. If you're trying to protect paint, that's one thing, but for a bikini top, I wouldn't even bother unless you plan to be driving in the rain with this setup.
If you still want some sort of seal, start here:
http://www.mcmaster.com/#rubber/=l2qb7t
The same thing could be available at your local hardware store. Think garage door seal??
Thu Jan 17, 2013 9:48 am
Are you planning to come to the tech day tomorrow? If you do, I am pretty sure we have something you can use around here (it is amazing the different types of door seals we have lying about).
Fri Jan 18, 2013 7:42 am
32,747,124 Views Powered by phpBB © 2000, 2002, 2005, 2007 phpBB Group.
