It is currently Sat Nov 23, 2024 10:23 am
Re: Project X
Mon Feb 11, 2013 9:34 am |
Re: Project X
The issue with H1 wheels are getting the inserts (plastic or magnesium). And recentering them so they don't contact your steering links. You can get cheap wheels all day long, but the inserts are pretty expensive as is recentering them. That's what a lot of people don't follow thru when they realize the work involved and for just about the price of Brand X beadlocks. Then you have the seal between the two halves. I agree they look cool. If you do go this route, also look into welding some round rod into the outside bead to stiffen them. I hear they bend pretty easy from a side impact. Some info: http://www.trailworthyfab.com/H1-Hummer-Wheel-Run-Flats
Mon Feb 11, 2013 9:54 am |
Re: Project X
Recentering is a concern. From what I understand I can compensate with 2" spacers until that happens. For now I'm just looking for beater wheels to get things mocked up. I figure by the time I actually get around to running this thing, I will have taken care of the recenter/instert issues. I hadn't heard about the bending issues. I've beaten the hell out of some H1 wheels, tires, and trucks in the past with no issues so I'll do some more research to see how much I should be concerned.
Mon Feb 11, 2013 12:17 pm |
Re: Project X
Area 51 is getting a little crowded these days. Project X is roommates with a Mustang and a Corvette. Spent the better part of today there. Progress being made...?
Fri Feb 15, 2013 8:19 pm |
Re: Project X
Remember to let me know when you are cutting off that exo, Willem just informed me that he wants to build tube bumpers.
Sat Feb 16, 2013 6:16 pm |
Re: Project X
Time to go on a diet, fat boy.
Sat Jan 25, 2014 11:11 am |
Re: Project X
Cool to see you working on this!
Sat Jan 25, 2014 11:47 am |
Re: Project X
What do you mean "I took too much off the top"?
Sat Jan 25, 2014 1:16 pm |
Re: Project X
Are the parental controls ON? I've seen Lipo before... I'm over 18... C'mon lemme see it!
Sun Jan 26, 2014 10:52 pm |
Re: Project X
Bad haircut joke. Sorry.
Mon Jan 27, 2014 12:12 am |
