Locking hub part deux
So Hockey Boy has an issue with the drivers side hub. It has not been locking in so last night he opened it up to replace it and was unable to get the big ring out. It looks like the center of the axle shaft has pushed outward and caused the ring to blow out from the center - now it is stuck in the housing where the outer ring goes. Any brilliant ideas?
Tue Feb 26, 2013 12:53 pm |
Re: Locking hub part deux
Put a block of wood under the accelerator? Can you push the axle back into place to gain some working room?
Tue Feb 26, 2013 2:23 pm |
Crazyone
Joined: Tue Jan 25, 2011 9:33 am Posts: 207 Location: Aurora, CO
Block of wood under the accelerator! Good one!
_________________ You will not see me cry because I do not sing the blues
Tue Feb 26, 2013 3:31 pm |
Wow, I say hit it on the end GENTLY (calling you out Greg) and see if you can get some movement. Let me know if I should stop by to help.
Did the bearing go kaput? Not sure how the outer axle would travel that far.
Tue Feb 26, 2013 6:13 pm |
TIM
Joined: Sun Nov 07, 2010 9:54 pm Posts: 41 Location: Denver
If it were mine I would soak the inside with pb blaster overnight then go at the axle and planetary gear of the lockout with a bfh and then hopefully you got enough room to get to the snap rings and spindle nuts.
Tue Feb 26, 2013 7:47 pm |
How about a little grease in there so they dont rust together....
Tue Feb 26, 2013 10:01 pm |
Wed Feb 27, 2013 1:09 am |
If memory serves me right he did rebuild / grease them within the last year. So something else is going on.
Wed Feb 27, 2013 8:53 am |
Wed Feb 27, 2013 9:06 am |
sbolt19
Put a fender washer & bolt into that axle stub and tighten it up, that will give you a little play in the gear, might be enough to take the pressure off of the snap ring & outter hub bolt ring, maybe enough to take a chisel and finish breaking that bolt ring so it can be replaced. Looks to me like he didn't put it back together right the last time and didn't get the gears to mesh before he put it all together.
Wed Feb 27, 2013 4:52 pm |
