It is currently Mon Nov 25, 2024 7:36 pm
[ 13 posts ] |
Head
I was lucky enough to get a great set of GT40 heads at the swap meet. I've never swapped a set of heads, but from the reading I've been doing it doesn't look took hard. What I know nothing about is how to evaluate their condition. Obviously, I could take them to a machine shop and have them checked out and possibly refurbished, but that's $$ I don't want to spend. Anyone have any advise on how to check out whether or not they can be installed as-is?
Sun Mar 31, 2013 12:12 pm |
Re: Head
I think they should at least be checked by a shop to see if they are true/flat. They can warp and probably make sealing difficult/impossible. I'm don't think there is a way to do that yourself, maybe I'm wrong. I don't know what to look for in the valvetrain.
Sun Mar 31, 2013 1:39 pm |
darkmagus
Joined: Wed Mar 09, 2011 10:47 pm Posts: 57 Location: Englewood
Re: Head
You just need a precision straight edge and a set of feeler gauges.
Sun Mar 31, 2013 3:12 pm |
REH
Joined: Fri Oct 07, 2011 12:28 pm Posts: 56 Location: Cortez
Re: Head
use a straight edge and feeler guage like stated above, then pour a little gas in the compression champers, if the valves hold gas they are good. check the valve bonnets and make sure that they are in good condition.
Tue Apr 02, 2013 8:57 am |
Re: Head
So is the head checked across the long length of the head, or across the short length? or both? diagonally?
What is an acceptable feeler gauge to fit under the straight edge?
Tue Apr 02, 2013 7:06 pm |
darkmagus
Re: Head
You'll have to check specs on what's acceptable. Here's a photo of the pattern to check in. Just make sure you use a precision straight edge and not something like a ruler.
Tue Apr 02, 2013 7:19 pm |
Re: Head
Cool thanks, I had no real idea what was involved. More simple than I imagined.
Tue Apr 02, 2013 7:27 pm |
Re: Head
Very cool, thanks!
Tue Apr 02, 2013 7:36 pm |
horseplay
Re: Head
I have a small repair shop in Evergreen I would be happy to check them out for you. Give me a call at the shop if you want to stop by. Rob C 303 679-1610
Tue Apr 02, 2013 7:46 pm |
darkmagus
Re: Head
I just noticed some of the lines aren't very clear but there should be 7 lines. There's variation on where to check between manufacturers but the one above is how I check with the addition of lengthwise in the center.
Tue Apr 02, 2013 7:49 pm |
Robs71sport
Re: Head
Tue Apr 02, 2013 9:23 pm |
Re: Head
Thanks for all of the tips, guys. I ended up taking them down to Scott at MPG heads to have him take a look at them. Got them hot tanked and cleaned up, and had Scott inspect the valve seats and guides. The good news is that they're in great shape and can be run as it. The bad news is that I need to find a set of rockers before they'll actually work. Anyone have a spare set of stock GT40 rockers laying around? Also, can I use the existing pushrods, or to I need to buy new?
Fri Apr 05, 2013 9:23 am |
JGZ
Re: Head
There were some at Colo.Auto last week.Already off.
Fri Apr 05, 2013 10:41 am |
[ 13 posts ] |
Users browsing this forum: No registered users and 124 guests |
