Register •
FAQ
• Login
It is currently Fri Sep 20, 2024 5:04 pm
[ 5 posts ] |
'79 Bronco full width high pinion Dana 44 housing...free!!
79 bronco high pinion Dana 44. I bought a complete diff to take the disc brakes off of for my brother in laws bronco. Therefore the axle is missing everything from the knuckles outward. I can include the knuckles that come off of his early bronco axle if desired. They have 5 month old moog ball joints in them but you will need everything else. I did not crack the diff cover to check the condition of the gears but i was told it was running and driving before i bought it so i assume they are ok. This would be a great way to get full width and high pinion for really cheap as long as you don't mind swapping your brakes on to this housing.
Wed Apr 03, 2013 6:56 am |
Re: '79 Bronco full width high pinion Dana 44 housing...free
If I were there, I'd consider doing this, but trussing at the same time and then swap all my goodies onto this axle. But really, I think D60 is my next step, or a 609 if I can swing it!
Wed Apr 03, 2013 6:59 am |
yobro
Joined: Sat Oct 29, 2011 3:01 pm Posts: 56 Location: S.W. Denver
What gears are in there?? I have a hp dana 44 cut for early bronco with disc to swap out dana 30 drum setup with 4.11 inboth. Would like for backup or maybe go full width down the road. Need to find place to store it and i'll post up later to inform.Thx
Wed Apr 03, 2013 7:32 am |
Wed Apr 03, 2013 6:30 pm |
Gone!
Thu Apr 11, 2013 9:23 am |
[ 5 posts ] |
