Register •
FAQ
• Login
It is currently Fri Nov 01, 2024 6:32 am
[ 8 posts ] |
Why Don't My Blinkers Blink?
freeheelbillie
Joined: Wed Sep 29, 2010 11:23 am Posts: 574 Location: Denver
They blink slow, or just stay constent on.
_________________ A nation of sheep breeds a government of wolves. (0======0)
Tue Dec 21, 2010 4:45 pm |
cobshane
Re: Why Don't My Blinkers Blink?
lots of things can cause those problems. I would first check bulbs for good contact on terminals might as well replace your flashers, cheap insurance. FIRST START, MAKE SURE charging system is good if you dont have good voltage it can cause that problem, I have kick myself in the head with this one, 13 to 14 volts is sufficient. Do they work better if engine is reved up with sigs on. if all checks out you probaly have some loose or bad wiring some were.
Tue Dec 21, 2010 5:20 pm |
freeheelbillie
Tue Dec 21, 2010 5:27 pm |
rdanford
Joined: Wed Sep 29, 2010 8:12 pm Posts: 169 Location: Windsor
Flasher relays...replaced both mine, totally shocked on how much they improved for $15!
_________________ Royce 1977 Bronco...EFI, ViperBuilt C4, PS, PB, cut with 33's - Rebuild coming 1987 Porsche 951...LS1 swap - SOLD 2006 4Runner V8 Sport Edition 1998 4Runner...DD with 333k and counting
Tue Dec 21, 2010 6:44 pm |
Either the flasher is bad or you don't have enough circuit current to make them flash. Bad bulbs, LED bulbs, bad grounds, disconnected or broken turn signal wires all reduce the circuit current.
Tue Dec 21, 2010 7:44 pm |
Lobobronco
Joined: Wed Sep 29, 2010 9:20 am Posts: 289 Location: Denver, CO
I would agree with the flasher.....
Had the same problem years ago. Easy and cheap place to start. Actually keep an extra one in the glove box these days!
Matt
_________________ Her name is Lucy...and well...that's who she is!
Tue Dec 21, 2010 8:16 pm |
The hazard flasher makes a good emergency spare and troubleshooter. It's interchangeable with the TS flasher.
Tue Dec 21, 2010 9:50 pm |
freeheelbillie
Wed Dec 22, 2010 3:23 pm |
[ 8 posts ] |
