It is currently Sat Nov 23, 2024 5:07 am
8 Years later, off to paint
jcb9089
Joined: Sun Feb 13, 2011 7:43 pm Posts: 266 Location: Falcon
Started this project with my father in June 2005 after I returned from being stationed in England. I was pretty naive about broncos back then, so it cost me more than it should have, but its finally off to paint in Ohio. Going with Deep Cherry Crystal Pearl and white flares/top.
Thu May 16, 2013 10:36 am |
Colorado75bronc
Re: 8 Years later, off to paint
Sounds like its gonna be beautiful when its done, can't wait to see
Fri May 17, 2013 1:06 pm |
The original paint job looks very similar to the first Bronco I ever remember seeing, back in Alaska in 98. That was the one that gave me the Bronco bug.
Fri May 17, 2013 1:12 pm |
jcb9089
Getting fitted prior to paint prep. There is a gap at the rear of the driver door from the rocker pushing the qtr panel back too far. So he is going to cut/weld both rear rockers and eliminate the seam. Other than that, looking good.
Wed May 29, 2013 8:59 am |
Checking gaps? That sounds like a professional move.
Wed May 29, 2013 6:36 pm |
jcb9089
getting close, some color added today
Wed Aug 07, 2013 1:42 pm |
Wow, that's going to POP!
Fri Aug 09, 2013 12:16 am |
jcb9089
Went with the Dodge Deep Cherry Red Crystal Pearl. For the longest time I planned on Burnt Orange, but love this color. White flares and top, Argent grey grill. My father installed hood vent support by cutting out original hood vents and mounting under cutout.
Fri Aug 09, 2013 9:43 am |
jcb9089
color before the clear. Getting close
Wed Aug 21, 2013 10:45 am |
Very nice, hood vents look great.
Wed Aug 21, 2013 10:56 am |
jcb9089
Thanks, think the hood pic had 3 coats of color and 3 more to go.
They are going to put a fine coat of rock guard on the top of the top and the dash. Hard to tell but the inside of the hood is lined with rock guard under as well.
Wed Aug 21, 2013 11:10 am |
jcb9089
Almost there, top gets painted tomorrow and put together on Sat.
Thu Aug 22, 2013 7:01 pm |
Mr. Lav
Joined: Sun Apr 17, 2011 11:33 am Posts: 200 Location: yoder, colorado
Dam that looks awesome, what ever happened to the white one?
Thu Aug 22, 2013 7:13 pm |
Dukietown
Wow that's a gorgeous paint job. Can't wait to see it complete!
Fri Aug 23, 2013 7:00 am |
Geologist
I like the color! Look forward to seeing it complete!
_________________ 1966 Bronco, rebuilt 302, Twin shift Dana 20, T19, 3.5 suspension lift, 2 inch body, 35x12.50 tires
Fri Aug 23, 2013 9:12 am |
jcb9089
Here is a couple more. Top goes on and then all the tedious but expensive little things need to be done.
Alex, had to part ways with the White one after I retired from the Military. Had 3 broncos, 2 projects and one complete. When projects sell, they seem to always lose money so I sold the complete on. Hated to sell it because the paint was amazing.
After all the work, I've learned to never sell again. I'm keeping this one and the half cab project I have too.
Fri Aug 23, 2013 7:41 pm |
That color looks great.
Sat Aug 24, 2013 8:35 am |
jcb9089
out in the sun
Sat Aug 24, 2013 5:43 pm |
kbank6
Looks great!
Sun Aug 25, 2013 9:28 am |
Beautiful paint job - that is going to be an amazing build.
Sun Aug 25, 2013 7:42 pm |
Geologist
Nice!!
Sun Aug 25, 2013 9:30 pm |
Stunning.
Sun Aug 25, 2013 11:10 pm |
Very nice!!
Mon Aug 26, 2013 1:57 am |
Awesome colors with perfect contrast
Magnificent !
Mon Aug 26, 2013 5:33 am |
jcb9089
Thanks, can't wait to get it shipped out to the springs.
Anyone know of a good hauling company, enclosed trailer?
Tue Aug 27, 2013 2:43 pm |
Your guy in Ohio does really nice work !
Have you considered moving the rear axle back an 1" to center it better in the wheel well ?
Tue Aug 27, 2013 4:10 pm |
jcb9089
I noticed that rear wheel too. They make bolt on kits to move it back 1". It will be on my list to move further back. http://www.offroaddesign.com/catalog/Zero%20Rates.htm
Wed Aug 28, 2013 9:01 am |
You also have the option of re-drilling the spring perch and upper plate.
Wed Aug 28, 2013 4:52 pm |
Colorado75bronc
That is beautiful
Wed Aug 28, 2013 7:45 pm |
Thu Aug 29, 2013 12:59 am |
