It is currently Fri Nov 01, 2024 2:30 pm
[ 9 posts ] |
4 degree steel shims
looking for 4 degree steel shims for the rear leafs, thanks
Fri May 31, 2013 4:25 pm |
Crazyone
Joined: Tue Jan 25, 2011 9:33 am Posts: 207 Location: Aurora, CO
Re: 4 degree steel shims
I have zinc 4 degree shims in stock here. Steel are pretty hard to find.
_________________ You will not see me cry because I do not sing the blues
Fri May 31, 2013 4:48 pm |
Fri May 31, 2013 5:19 pm |
What does zinc do for me? Sounds risqué
Fri May 31, 2013 9:16 pm |
Corrosion resistance. Are they solid zinc or just coated with zinc?
Tue Jun 04, 2013 3:19 am |
Crazyone
They are solid zinc. Zinc is softer than steel but works well on heavier vehicles because it tends not to work its way loose which sometimes happens with steel wedges. The zinc holds up well too. The only time I have seen one fail is on a cement truck. That was a little too much weight!
Tue Jun 04, 2013 8:23 am |
might be interested.. i need to re-measure my angles this week I think I have too much pinion angle..
Tue Jun 04, 2013 8:28 am |
plumbdoctor
How much for these risqué zinc wedges??
Tue Jun 11, 2013 10:14 pm |
Crazyone
Wed Jun 12, 2013 8:40 am |
[ 9 posts ] |
Users browsing this forum: No registered users and 61 guests |
