www.ColoradoClassicBroncos.com - View topic - 4 degree steel shims
It is currently Fri Nov 01, 2024 2:33 pm
Reply to topic  [ 9 posts ]
Post 4 degree steel shims
looking for 4 degree steel shims for the rear leafs, thanks
Fri May 31, 2013 4:25 pm
Post Re: 4 degree steel shims
I have zinc 4 degree shims in stock here. Steel are pretty hard to find.
Fri May 31, 2013 4:48 pm
I've read good things about this guy:
http://www.4crawler.com/4x4/ForSale/Shi ... troduction
Fri May 31, 2013 5:19 pm
What does zinc do for me? Sounds risqué
Fri May 31, 2013 9:16 pm
Corrosion resistance. Are they solid zinc or just coated with zinc?
Tue Jun 04, 2013 3:19 am
They are solid zinc. Zinc is softer than steel but works well on heavier vehicles because it tends not to work its way loose which sometimes happens with steel wedges. The zinc holds up well too. The only time I have seen one fail is on a cement truck. That was a little too much weight!
Tue Jun 04, 2013 8:23 am
might be interested.. i need to re-measure my angles this week I think I have too much pinion angle..
Tue Jun 04, 2013 8:28 am
How much for these risqué zinc wedges??
Tue Jun 11, 2013 10:14 pm
Wed Jun 12, 2013 8:40 am
Users browsing this forum: No registered users and 72 guests
32,746,513 Views Powered by phpBB © 2000, 2002, 2005, 2007 phpBB Group.
