www.ColoradoClassicBroncos.com - View topic - cheap a$$ family cage
It is currently Sun Nov 24, 2024 5:29 pm
Reply to topic  [ 8 posts ]
Post cheap a$$ family cage
Here is my combo slice of a 4 pt smittybilt rollbar and a 6pt smittybilt front cage (thx gunnibronco) into a passable family cage
Tue Aug 13, 2013 5:04 pm
Post Re: cheap a$$ family cage
Looks good. Glad its getting reused, and not cut up for other projects.
Did it fit well? Sit flat on the floor? Just wondering how whacked out my tub is.
Tue Aug 13, 2013 5:34 pm
Using my existing roll bar holes the front was above the floor by 3/4 to one inch
Tue Aug 13, 2013 6:05 pm
That could be because I put it in after welding in new front floor pans. My body crossmembers (under the driver & passenger feet) were cracked & bent from the body mount out, on both sides. I used a jack, a BFH, angle iron, and a welder, to try to straighten them before putting the new floors in, but I bet they didn't go back in just right.
Tue Aug 13, 2013 6:10 pm
It actually worked out great for me since I tightened all the rear 4 legs first then cranked down the front and it closed the 1/4 inch extra gap I had at top of the door
Tue Aug 13, 2013 9:19 pm
Wed Aug 14, 2013 7:38 am
HIX, I would love to see this up close and pick your brain some. I had a few ideas similar to this for the rear. Curious why you kept the original rear legs versus just building new stretchers on the top.
Adam
Sent from my HTC One using Tapatalk 2
Wed Aug 14, 2013 5:54 pm
The hoop would have been too close to the tailgate and the top would not have fit. You cant just slide the hoop forward to the rear of the wheelwell because of the filler tube box out on the driver's side.
I wanted to build this with no bending, just cutting and welding. Ill probably add spreaders on top at some point
Wed Aug 14, 2013 9:08 pm
Users browsing this forum: No registered users and 19 guests
33,008,938 Views Powered by phpBB © 2000, 2002, 2005, 2007 phpBB Group.
