Gregg wrote:How does it feel to be a "one upper"?
- Rox Crusher
- Official CCB Member
- Gregg
My wife thinks that's cute.
Seriously, I'm a little put out that I'd have to take your bumper off to steal those chrome hooks.
- Gregg
Nothin to fancy. I just screened in the hood vents on JYDs new old hood. Thanks again to JGZ and Viper for gettin it back.
- Viperwolf1
Gregg wrote:Nothin to fancy. I just screened in the hood vents on JYDs new old hood. Thanks again to JGZ and Viper for gettin it back.
Looks good. It's gonna make it tougher for Rox to steal plug wires when he burns his up.
- Rox Crusher
Shawn, that looks great !
- Kinder
Nice, mind if I steal the idea for Bubba Smurf? Of course I'll make them chrome or stainless, lol!
- Gunnibronco
I used a product called Frog Skin that is used on snowmobiles. It is a mesh cloth that allows air flow, but doesn't let water through. It comes in different grades of mesh & shapes/sizes.
- ZOSO
- Moderator
Viperwolf1 wrote:Gregg wrote:Nothin to fancy. I just screened in the hood vents on JYDs new old hood. Thanks again to JGZ and Viper for gettin it back.
I got a chuckle about that at the platte river meet. Saw that Jeff still had the ugly grey plug wires he bought in moab on there. He was all about having those purple wires.
- Rox Crusher
ZOSO wrote:Viperwolf1 wrote:Gregg wrote:Nothin to fancy. I just screened in the hood vents on JYDs new old hood. Thanks again to JGZ and Viper for gettin it back.
Those purple wires are now on the JYD !
- Gregg
You said they were off blue! Crap ! Purple clashes with pink.
- ZOSO
- Moderator
I decided to keep my bronco. I have started to work on it again. Goal is to try and get it running and driving by spring if nothing needs to be rebuilt. I cut out the drivers side. Since it's stock height I took my spare from my 79 and am making sure a 37 will fit on stock suspension. So when I go with a 3.5" lift they should clear fine. As of now all will work great. I'll get some pics up later.
- ZOSO
- Moderator
un-cut stock suspension tryin to fit a 37.
fender cut.
inner fender cut and widened.
Front at full stuff on factory bump stop. Tire does rub when turning. I plan to run a 3.5" lift with a bump stop so it wont really stuff this hard.
fender cut.
- ZOSO
- Moderator
rear cut out.
rear wheel wells "flaired" at filler neck openings.
rear tire at full stuff. I plan to cut and widen the rear wheel wells 2-4". that will give plenty of room for tires.
- Kinder
Sexy, do you have a build tread? If not start one up.
- Jesus_man
kinder wrote:Sexy, do you have a build tread? If not start one up.
Yes - I want an easy place to find your thread when I start in on mine!
- ZOSO
- Moderator
Jesus_man wrote:kinder wrote:Sexy, do you have a build tread? If not start one up.
viewtopic.php?f=3&t=1864
here you go. I havent updated it but I also lost a lot of steam on the project the last 9 months.
- Eck
OJ got to move into his new home. Let the upgrade scheduling begin!!
You gotta look close but he's in there!
- Rox Crusher
congrats on the new digs...........detached garage is nice to have
looks like your all set up for the technical support crew to come over and sit on the couch and do some "armchair quarterbacking"
- Viperwolf1
I bet you could park 10 Broncos on that driveway.
- Eck
I would be happy to have some armchair quarterbacks. Sounds like I have room for about 10. I've got a nice list of mods that I'd like to get done this winter (not counting a possible engine swap). So there should be plenty of opportunity.
The previous owner even left a mini fridge behind so there should even be a few cold ones available for said armchair QB's!
- Justin
Sweet congrats! That garage is a major upgrade. Now you need more tools!
- Jesus_man
Congrats! Yes, detached is always cool. Noise transfer from attached garages usually don't make other family members happy!
And if you extend your retaining wall up a couple more feet, you have a built-in RTI ramp!!
- crawlercreations
Today I built and installed my own gear banger. I've been wanting one for a while now so I decided to build it myself and save some money. Everything I used is stuff I had around my house so I spent a total of $10 on another stock np435 shifter I cut up for this. I wanted to keep my shifter in case this didn't work out and also to have as a spare.
- Kinder
I've noticed some are sloppy, what type of joints / pivots did you use?
- crawlercreations
kinder wrote:I've noticed some are sloppy, what type of joints / pivots did you use?
I welded a 5/8" I.d. 3/4" wide sleeve to the end of the shifter nub and the same to the new shifter lever. The linkage has a 3/4" I.d. so it fits the sleeves nicely. The 5/8" bolt size probably helps a little with tightening things up. I used a 3/4" shank, 5/8" hole with high misalignment inserts and the new shifter mount. It is a little sloppy but better than I was expecting. I have an idea on how to tighten it up but it doesn't bother me at all right now so I'll deal with it for a while before I think about changing things.
- landshark
Ya mine is super sloppy. I might mess around with it to see what I can do to get rid of the slop. But it's cold. Brrrrrrr
- crawlercreations
I know I'm not the only person working on my Bronco! Today I removed my stock front shock towers and built some new shock mounts on my tube core support inner structure. It will allow my shocks to stop bottoming out and make the ride that much smoother. I also pulled my door inserts and shot some color on them finally. Gotta mask them off and shoot the 2nd color tomorrow or Thursday. I also checked it over and found the radiator is leaking out of both end caps. Anyone have a good one laying around cheap? Guess I'll be taking one of my 3 to a radiator shop to be rebuilt. Any suggestions on a radiator shop?
Last edited by crawlercreations on Mon Dec 16, 2013 7:24 pm, edited 1 time in total.
- crawlercreations
Painted the inserts. Just need to install them now.
- Justin
They're too clean! Nah, looks great!
- Rox Crusher
crawlercreations wrote:Painted the inserts. Just need to install them now.
those look great !
