www.ColoradoClassicBroncos.com - View topic - Anyone a member of Colorado4x4.org?
It is currently Mon Nov 18, 2024 10:26 am
Reply to topic  [ 11 posts ]
Post Anyone a member of Colorado4x4.org?
I was looking at some pics of and Eb that one of their members did he goes by Dsmith01. Wanted to get his info since he has done what I have to or most of what I have to. Let me know.
Thanks
74 Ranger
65 Fastback
Tue Dec 28, 2010 8:14 pm
Post Re: Anyone a member of Colorado4x4.org?
Thanks, I want to pick his brain about all his hard work.
74 Ranger
65 Fastback
Wed Dec 29, 2010 1:09 am
Hello! This is dsmith01 from colorado4x4.org. Got a PM from zillicon over there and thought I'd register and say hi.
I've been hanging around classicbroncs.com for a while but its good to see a colorado group formed!
My Personal Website -
Wed Dec 29, 2010 3:52 pm
dsmith - welcome to the site. Sounds like you have an awesome Bronco - looking forward to pictures.
Wed Dec 29, 2010 4:39 pm
I saw your thread on google through Colorado4x4.org and wanted to pick your brain. I am doing alot of the work you have done and wanted to know if you could post that thread on CCB under General 4x4 technical. I ran into an issue with my truck when I pulled the kick panel and the DS drooped 1/4 "-1/2" and wanted to see how hard it was to get it back to normal.
Thanks, glad to see another bronco crazy!
74 Ranger
65 Fastback
Wed Dec 29, 2010 10:43 pm
Drivers side cowl/windsheild? Thats what mine did. Not too bad to get back into place although it would have saved a bunch of time if I would have braced it first oops .
First I measured the passengers side. Get measurements for the door opening, floorpan to cowl, floorpan to top (if you have one on the EB). I then used a rachet strap and a floor jack with a 3 ft 2x4 to lift and brace the DS cowl while I welded the kick panel in place.
It took a couple tries to get it right and I ended up cutting and re-welding a few times. After I thought I had everything lined up right I used just enough welds to secure it enough to hold the door. With the door on you can check alignment in the door opening and the seal along the windshield and top.
Here's a pic before I tacked the door post in place.
I hope it helps. If you need measurements I can get them for you tomorrow.
Wed Dec 29, 2010 11:47 pm
Did you have the cowl off before so that it did not interfere with pushing up on the windshield frame? Was your kick panel where you noticed it (at the bottom where it should line up with the inner rocker)? Thanks for the help your pics look freakishly similar!
74 Ranger
65 Fastback
Thu Dec 30, 2010 12:00 am
I honestly can't remember the order the cowl was put on. Either before or after the kickpanel/door post. I moved things around so much and re-tacked stuff in place when it looked right. Again, my method was not science.
Are your pictures in another thread? If not, post them up. I'm interested to see what you're working with.
Sun Jan 02, 2011 5:47 pm
Here is where i was to start and where I am now. Let me know what you think. I have more pics under member rigs. I have to move the kick panel about 1/4" up from this pic. Although I do have the upper bracket on the inside of the kick panel bolted in so maybe I don't have to move it that much.
74 Ranger
65 Fastback
Sun Jan 02, 2011 10:28 pm
I think that looks pretty good vertically. I'd be more concerned about the kick panel's horizontal position. I used the indent in the kick panel as a guide for where it should be positioned vertically. Your's looks about the same as mine does.
I don't think I'm going to be able to find the original measurements from when I did this a year ago but I can get some new ones tomorrow for you. Your best bet may be to tack your door post in place and mount your door. I know its a PITA but it really is the best way to check if everything is lined up.
Mon Jan 03, 2011 12:43 am
Don't worry about the measurements I will get the PS and compare...I checked from the floor to the top and striker to hinges and it looks pretty close, within a 1/4 of an inch. I may just have to persuade it a little more. Thanks for your input.
74 Ranger
65 Fastback
Mon Jan 03, 2011 11:35 am
32,896,905 Views Powered by phpBB © 2000, 2002, 2005, 2007 phpBB Group.
