Register •
FAQ
• Login
It is currently Sat Sep 28, 2024 7:07 am
[ 6 posts ] |
35's Mickey Thompson Baja MTZ's
Dirtheadz
Full set of 35's. Mickey Thompson MTZ's Have 9/32 (5/16 of inch). Show some rock rash. On 15x8 steel wheels. $250 for the set. Call/ text or PM me. In the springs. 719-237-0999
Sat Dec 07, 2013 9:53 pm |
Dirtheadz
Re: 35's Mickey Thompson Baja MTZ's
Here's a pic
Sat Dec 07, 2013 10:14 pm |
Dirtheadz
Here's the depth
Sat Dec 07, 2013 10:16 pm |
Interested, can I get a pic showing the wear pattern on the tires and what is the back spacing on the rims.
Sun Dec 08, 2013 10:43 am |
B.O.B.
If those are normal wagon wheels then I believe that b.s. should be 3.75 inches. usually 15 x 8 -19mm offset.
best way to figure out back spacing: take width of wheel and add .5 inch. divide by 2. that is the center of the wheel (0 offset or for a 8" wheel 4.25 backspacing). Then remember there is about 25mm in a inch, if its + offset then add to backspacing, -offset subtract.
Sun Dec 08, 2013 12:14 pm |
Dirtheadz
SOLD!!!!!
Sun Dec 08, 2013 1:01 pm |
[ 6 posts ] |
