www.ColoradoClassicBroncos.com - View topic - Explorer Drive-train Swap
It is currently Sat Sep 28, 2024 7:10 am
Reply to topic  [ 7 posts ]
Post Explorer Drive-train Swap
The shop is finished and I have some money back in the bank, time to start acquiring parts for the mall crawler.
What is everyone's opinion of the 4R70W?
Has anyone done this swap local?
I am thinking of just buying a complete Explorer and swap motor and trans.
If I go this route do I get the adapter for the D20 or run a np205?
I don't care too much about the really low range, this is going to be a paved road driver. I just want to have 4wd when I am in the mountains in the snow.
Wiring, is it easier to run the engine harness and a separate trans controller or harvest everything from an explorer and use the wiring?
66 1/2 Cab Rock Toy
68 Mall Crawler (someday)
Fri Dec 13, 2013 4:46 pm
Post Re: Explorer Drive-train Swap
I can chime in.
I did the Expoler 5.0 and 4R70W swap before the OBDII hybrid option was viable.
So I had to buy the trans controller, the TFI distributor and computer for the 5.0, and the EFI wiring harness. Probably about 1400 - 1500 bones right there.
Along comes Gary (EFI Guy) who pares down an Explorer harness to control engine and tranny but he eliminates all of the non-essential stuff required for the Explorer. You would have to contact him to get his pricing but going this route says a bunch of money and you end up with a better set up in my opinion.
So if you can get a complete low mileage Explorer donor you are golden.
I retained the D20 by using the AA adapter which requires replacing the output shaft but I was going to have the transmission rebuilt anyway so I felt that was the way to go.
I love the OD but you need to factor in final gearing for your intended use (mall crawler & hiway cruiser?).
Let me know if you have any specific questions.
Fri Dec 13, 2013 5:25 pm
Rox,
How much longer is the 4R70W and the D20?
Have you found any downsides to this set up?
Thanks for EFI Guy, his harness looks like it would be the best way to keep it simple. Is he local? I found him on CB.com.
Thanks
66 1/2 Cab Rock Toy
Fri Dec 13, 2013 5:47 pm
He is right here in good ol Mile High.
The combo is only about 1-1/4" longer than C4.
Only down side for me is the need to re-gear from 3.5 to 4.88 or 5.13 which I haven't done yet.
Fri Dec 13, 2013 5:55 pm
Use the AA zf/d20 adapter & save some cash. There are a couple of folks on CB.com that have gone this route.
Fri Dec 13, 2013 7:46 pm
I have a 4R70W for ya! and the explorer t-case if you want it. make me an offer I cant refuse........
Wed Dec 18, 2013 11:36 am
66 1/2 Cab Rock Toy
Mon Dec 23, 2013 2:50 pm
32,361,451 Views Powered by phpBB © 2000, 2002, 2005, 2007 phpBB Group.
