www.ColoradoClassicBroncos.com - View topic - NoCo Engine Builders
It is currently Wed Jun 26, 2024 4:31 am
Reply to topic  [ 7 posts ]
Post NoCo Engine Builders
As with most projects my '68 had it's own plan in mind. Instead of lockers, axles and new gears over the winter I get to replace the engine. Not sure what happened other than the bearings ended up in the oil. Have pretty much decided to replace the 302 with a 351W and looking for recommendations on engines builders in Northern Colorado that understand builds for trail rigs/daily driver 4x4s. Would like to have it built rather than buy a complete unit and then have to swap out parts to get the torque/HP where it's needed.
Mon Dec 16, 2013 9:49 pm
Post Re: NoCo Engine Builders
Call Scott at MPG Heads 303-762-8196
He is in Englewood so not exactly in NoCO but in my opinion well worth it (you are talking about spending $2k or more here)
Tue Dec 17, 2013 11:29 am
Thanks figured I'm in for at least $3,000 when all is said and done.
Tue Dec 17, 2013 2:07 pm
http://cosprings.craigslist.org/pts/4247332578.html
Not sure if you found a starting block but did see this morning don't know anything about it. I love my Windsor .
Tue Dec 17, 2013 3:57 pm
Have you thought about doing it yourself? There's two of us up here that are doing it.
Tue Dec 17, 2013 10:14 pm
The thought briefly crossed my mind. Just don't have the time and a warranty is nice to have (wife saw the guys on Fast N' Load wipe two new motors). Haven't built an engine (car or truck anyway) in over 20 years so I figured I'd let the experts do it. I'll do the removal/installation though.
Wed Dec 18, 2013 12:30 pm
call Phil at BG Automotive in Ft. Fun. Really good buddy of mine and has had a couple engines rebuilt up there. Has a lot of good off-road knowledge as well. Has helped build a couple of KOH trucks and a Baja 1000 truck as well.
Fri Dec 20, 2013 7:35 am
30,941,679 Views Powered by phpBB © 2000, 2002, 2005, 2007 phpBB Group.
