It is currently Sat Sep 28, 2024 1:22 pm
[ 7 posts ] |
Broncoguy73
Joined: Mon Feb 20, 2012 10:09 pm Posts: 126 Location: Highlands Ranch
EFI fuel hose
Is there any reason whey I cant run regular fuel line for my return line or do i have to run EFI rated?
Thu Jan 02, 2014 2:16 pm |
D&D72
Re: EFI fuel hose
I think its ok cause its not high pressure on the return side.
Thu Jan 02, 2014 4:23 pm |
Re: EFI fuel hose
Yes run regular hose pre high pressure pump and on the return line. That high pressure stuff is expensive!
Thu Jan 02, 2014 5:13 pm |
Broncoguy73
Re: EFI fuel hose
Yes it is, that's why I ask. So I will run it from the tank to LP to accumulator then to the HP and also the return. Great will save a lot of money.
Thu Jan 02, 2014 5:18 pm |
sbolt19
Re: EFI fuel hose
I think your entire supply line has to run in EFI line, but return lines don't have to. I'd have to go out and check mine to see if that is what I did, but if memory serves me, the standard line will collapse under the pressure of a HP pump.
Fri Jan 03, 2014 12:54 pm |
Broncoguy73
Re: EFI fuel hose
i have EFI rated line from the HP pump to the motor so Im good there.
Fri Jan 03, 2014 5:16 pm |
Re: EFI fuel hose
I've been running low pressure carb fuel line from the tank to the LP pump, to the accumulator, to the HP pump for 2 years now with no problems.
Fri Jan 03, 2014 6:07 pm |
[ 7 posts ] |
