www.ColoradoClassicBroncos.com - View topic - 300m bc output ?
It is currently Sat Nov 16, 2024 5:21 pm
Reply to topic  [ 12 posts ]
 300m bc output ?
Post 300m bc output ?
Does anyone have obe of these...is there a way to verify its a 300m steel?
Fri Jan 03, 2014 6:40 pm
Post Re: 300m bc output ?
Is this the T-case output?
Fri Jan 03, 2014 7:17 pm
Yes sir
Fri Jan 03, 2014 11:39 pm
Are they still made? I'd be pretty interested. All the references I could find were from around 2005.
Sat Jan 04, 2014 12:45 am
I think the BC shafts were made to the same dimensions as the stock shafts. Unfortunately the stock shafts are one of the few parts that don't have a dana part number stamped on them. There could be some differences in the radiuses between the journals and splines though. The stockers are as square cut as can be.
Sat Jan 04, 2014 1:20 am
I looked at my spare one vs the 300m shaft and the machine work is night and day different. . Phil instead of a breather the guy installed a hose fitting and reason?
Pictures
Stock output
300m
300m on left
Sat Jan 04, 2014 9:38 am
the probably added the hose fitting so they could locate the breather up higher
Sat Jan 04, 2014 11:59 am
Thats what I was wondering or extra oil port?
Sat Jan 04, 2014 12:40 pm
Sun Jan 05, 2014 1:15 am
What's up with that bearing in the stock output shaft? Looks like more than 13 rollers and looks like some kind of center race.
Sun Jan 05, 2014 1:19 am
First does that look like a aftermarket shaft..? Second I have a 1" body lift so hopefully it's enough. . I have the roller bearing packed in grease with a tube insert holding them in works good
Sun Jan 05, 2014 8:42 am
Yes it does look aftermarket.
Sun Jan 05, 2014 11:54 am
32,888,459 Views Powered by phpBB © 2000, 2002, 2005, 2007 phpBB Group.
