Register •
FAQ
• Login
It is currently Sat Nov 16, 2024 3:53 pm
[ 7 posts ] |
B.O.B.
check engine light
What is the best way to wire the check engine light. I have a wire from my harness, would like to use the brake light. What is the best way to do this?
Bobby
Fri Jan 03, 2014 2:42 pm |
Re: check engine light
Fri Jan 03, 2014 3:51 pm |
B.O.B.
I believe I still have mine (somewhere ). I guess my question is what wire to where and so forth. I figure the harness wire goes to the light but what grounds it.
Fri Jan 03, 2014 4:03 pm |
Computer supplies the ground for the light at pin 17. Power to the light is constant with key on.
Fri Jan 03, 2014 5:13 pm |
airbur
check engine light
Sat Jan 04, 2014 6:37 am |
As I recall the RJM harness provided the wire to pin 17 but you need to provide the +12V wire to the light.
Sun Jan 05, 2014 1:06 am |
plumbdoctor
My rjm provided both wires, pin 17 and pin 37 or 57 or power from relay or something like that
Sun Jan 05, 2014 5:06 am |
[ 7 posts ] |
