It is currently Fri Nov 01, 2024 10:24 am
[ 12 posts ] |
Stock dash mounted throttle cable
I think these were on the old 3 spd pto trucks. Dash mounted and goes down to the throttle inside the truck.
Wed Jan 08, 2014 4:13 pm |
Moab Mike
Re: Stock dash mounted throttle cable
I have one and the bracket that goes on the pedal, good condition......$40.00.
Wed Jan 08, 2014 4:22 pm |
Moab Mike
Wed Jan 08, 2014 9:21 pm |
If I didn't throw mine away it's all yours Kirk. I'll take a look for it and let you know.
Wed Jan 08, 2014 9:28 pm |
Found it! I'll put it with your strap for the next time we meet up. I usually throw that stuff away so something must have stopped me from tossing it just for you.
Wed Jan 08, 2014 9:37 pm |
Moab Mike
Thu Jan 09, 2014 4:31 pm |
Someone setting up a high idle cable for those cold mornings?
Thu Jan 09, 2014 6:01 pm |
Thanks fellas, I'll take you up on the free one. And you read my mind, high idle baby.
Got the idea from Brian's 7.3 when it up idled on cold mornings, then the plow truck I've been using does it as well. Awfully nice on those cold mornings to help the truck warm up.
Thu Jan 09, 2014 8:08 pm |
put in an exhaust brake too. close it when cold and idle it up. even faster warm ups.
Fri Jan 10, 2014 7:15 pm |
I like, when I upgrade my turbo I'll look into it.
Fri Jan 10, 2014 9:37 pm |
I've actually disconnected the plug from my exhaust back pressure valve on the Super Duty. Got tired of the damn thing staying open after I started driving. However, very good for warming the ol' dino furnace up, just as Rob said. Maybe even hook it up on a second throttle cable?
Fri Jan 10, 2014 10:10 pm |
I've kept my EBV because on my DPtuner I use the decel tune. Which works very well. And I like to wake up me neighbor when it kicks on at 5am.
Sat Jan 11, 2014 9:46 am |
[ 12 posts ] |
Users browsing this forum: No registered users and 36 guests |
