It is currently Fri Nov 01, 2024 10:37 am
[ 8 posts ] |
Stock coil springs
Looking for a set of stock coils, preferably with more spring than sag in them. If you've got some stock height shocks that weren't made 20 years ago, all the better.
Lemme know whatcha got and how much I gotta shell out. Thanks.
Mon Jan 20, 2014 8:48 pm |
plumbdoctor
Re: Stock coil springs
Duffs 2" and an add a leaf... Think about it.... You know you want them....
Wed Jan 22, 2014 9:25 pm |
What's the threshold before I have to start thinking about offset radius arm bushings, drop trac bar mounts/trac bar risers, etc.?
Wed Jan 22, 2014 9:26 pm |
plumbdoctor
You'll be fine
Wed Jan 22, 2014 9:32 pm |
plumbdoctor
I will measure against some old stockers I have... But I doubt you will need any additional items... I think I have some 4 degree bushings as well , might have to dig for a bit to find those though
In short the threshold is you want them ....... ....... Yes
Wed Jan 22, 2014 9:36 pm |
Strong with this one the force is.
Wed Jan 22, 2014 9:55 pm |
You can go up to about 3.5" without radius arm and trac bar issues. Much above that and stuff needs to be addressed.
Wed Jan 22, 2014 11:41 pm |
RJLougee
Back in "the day" we used to swap the '78/9 F150 coils into the front for an inexpensive and easy lift good for about 1-1.5" and better handling. Basically, it would level the rig out compared to the back if you were running without a hard top.
I'm in NC at present, but I've got some springs you can check out when I get back the 30th. Joe
Thu Jan 23, 2014 9:08 am |
[ 8 posts ] |
Users browsing this forum: No registered users and 86 guests |
