It is currently Sat Nov 23, 2024 10:05 am
Reply to topic  [ 2657 posts ]  Go to page Previous  1 ... 51, 52, 53, 54, 55, 56, 57 ... 89  Next
Tried to start it but the battery is dead.
Tue Jan 14, 2014 6:09 pm
Tue Jan 14, 2014 6:48 pm
Tue Jan 14, 2014 7:20 pm
Tue Jan 14, 2014 8:17 pm
No, not with my good looks or my wit. I cut it like I cut the cheese...smooth and steady with a slight touch of pressure. I do prefer the smell of metal though. My blend is just a tad rich.
Tue Jan 14, 2014 9:37 pm
Thu Jan 16, 2014 7:51 pm
Brought it home a new friend to play with.
Mon Jan 20, 2014 7:04 pm
Nice! What are your plans with it?
Mon Jan 20, 2014 7:20 pm
Uber LUBR of course. So many guys with sweet uncut Broncos, I just couldn't help myself when a solid builder came along.
Mon Jan 20, 2014 8:12 pm
Mon Jan 20, 2014 9:47 pm
Mon Jan 20, 2014 10:09 pm
ya thats it, met the guy a few years ago at the auto parts store.. he was trying to replace the rear driveshaft
Mon Jan 20, 2014 10:59 pm
He's a member on here. Turns out he used to work at the same place I work now.
Mon Jan 20, 2014 11:01 pm
Terrible One got some new brake fluid, brake cylinders adjusted, turn signal flasher, and plates. Tomorrow, it goes to work.
Tue Jan 21, 2014 10:14 pm
Tell me what LUBR means again... I'm glad you got another one! Peter
Tue Jan 21, 2014 11:41 pm
Peter LUBR is shorthand for a Lifted Uncut BRonco.
Today, I had my "new" welder delivered. I'll need a 50 amp circuit to drive it. Its physically large, but it does have a 60% duty cycle @ 225amps. So I'll be able to melt about anything I want. This isn't mine, but its the same model, mine is clean and not heavily used:
http://www.ebay.com/itm/DAYTON-225-AMP- ... 7675.l2557
I just ordered two of these fuel tank vent/roll over valves:
http://www.tanksinc.com/index.cfm/page/ ... /prd98.htm
I haven't had any troubles since I upgraded tanks and replaced the gas caps with new (Gates #31702). The caps I got are listed as having a vac/pressure relief valve. But when I pull my caps off after running for a while, I hear air being sucked in, it is also pulling fuel from my aux tank when the main tank is emptied. Also, if I fill the main tank from the aux tank, there is air pressure released from the tank when the cap is removed. So whatever relief valve is built in is not big enough to allow enough venting to keep up with the tank draining/filling. I don't want to find out where/when/why this might be a problem, and I'll just add the vent valves. My truck isn't parked in a garage, so I don't think the smell will be a problem.
I'm starting a list of upgrades/repairs I need to make to feel good about going to Utah at the end of April.
I also passed my electrical rough in and framing home inspections, today. So I can add outlets, lights, switches, etc and also drywall. Closing in on "finishing" my remodel = more time for my Bronco.
Tue Jan 21, 2014 11:52 pm
Chad - maybe you could make that siphoning from the aux tank work for ya?? It probably makes the pump work harder tho...
Glad to hear your remodel is moving onto the next step!
Wed Jan 22, 2014 1:50 am
Wed Jan 22, 2014 9:15 am
I hear ya! But if you put that vent upstream of the aux tank, that would put less strain on the pump sucking the fuel into the main tank. Just sayin'...
But it's nice to know you always have that extra fuel in the aux tank.
Wed Jan 22, 2014 9:31 am
I'm going to put a vent on each tank. Both are developing strong vacuum when drained, and the main tank is positively pressurized when its filled from the aux tank.
Wed Jan 22, 2014 9:33 am
Got all the glass reinstalled with help, Guidance and most of the labor from Hockeydad. Thanks Greg!
Sun Jan 26, 2014 9:06 am
Finished rewiring the garage. New subpanel for the win. Many thanks to Mike for his help!
Sun Jan 26, 2014 9:46 am
Finally went ice racing.
I'm so good at it that I managed to take 94th place in a field of 15 cars.
Sun Jan 26, 2014 10:10 am
AWESOME. Looks likes greet weather too. Those tires make your truck look huge.
Sun Jan 26, 2014 10:49 am
Sun Jan 26, 2014 11:25 am
Too much fun!
Sun Jan 26, 2014 12:20 pm
Scored me some 4:88 gears.
Let's see if I can scrounge up dinero for ARBs before Moab.
Sun Jan 26, 2014 4:47 pm
Sun Jan 26, 2014 5:20 pm
Sun Jan 26, 2014 7:06 pm
Mon Jan 27, 2014 1:43 am
32,971,627 Views Powered by phpBB © 2000, 2002, 2005, 2007 phpBB Group.
