It is currently Sat Nov 23, 2024 10:29 am
I went out to the garge looked at the Bronco then came back in side.. it was too late and too cold for me tonight :(
Hopefully get some time tomorrow to work on it.
Tue Jan 28, 2014 9:00 pm |
Friday
Just got the frame back from sandblasting. If anyone else needs to do this the place I went is Rocky Mountain Memorials down on Fountain and Hancock in Colorado Springs. They do headstones and such but do other things as well. They did an excellent job and it was the best $150.00 I've ever spent on my project. Hands down. I'll post pics later.
Thu Jan 30, 2014 2:06 pm |
That sounds awful familiar to the place I had sandblast my bumper. Was very reasonably priced then too!
Fri Jan 31, 2014 1:56 am |
Thanks Kirk and Phil for the help with the axle this morning.
I think I found where it came from, Kirk would you mind comparing it to this picture for me ?
Sat Feb 01, 2014 4:12 pm |
Error404
Joined: Fri Aug 16, 2013 8:33 am Posts: 92 Location: COLORADO SPRINGS
Looks Legit! Ha!
_________________ 1996 bronco 4bt sas . 1972 bronco 10k mi no motor no trans..unfortunately rolled in 1973. Left for me to bring back from the dead.
Sat Feb 01, 2014 11:35 pm |
New to me door hinges installed. The door actually closes without the window frame rubbing against the hard top now.
Pull the door apart and lubed up the locking mechanism/latch. Reinstalled and resecured all rods. I can open my door from the outside again, without having to leave my vent window unlocked.
Sun Feb 09, 2014 5:46 pm |
Part 2 Headed out the door to go to Home Depot. Starter is out on the Stroppe'd. Figure it will be a quick swap with Terrible One. Long tube headers on Stroppe'd disagree. Wind up having to pull the PS header and all spark plugs on that side to get enough wiggle room to remove the starter.
Sun Feb 09, 2014 9:04 pm |
Terrible One got a new to me, best price ever starter this evening. Also managed to wiggle one stock height Wildhorses coil spring in. You want to see Bronco lean? Look at a Bronco with one coil replaced.
Fri Feb 14, 2014 8:28 pm |
Sun Feb 16, 2014 5:31 pm |
Cleaned the garage that surrounds it. Way worth the hours it took. Thanks again, guys.
Sun Feb 16, 2014 5:37 pm |
Moab Mike
Sun Feb 16, 2014 6:03 pm |
Sun Feb 16, 2014 7:34 pm |
Gregg
My old stock latch was a pain to latch/unlatch. I grabbed a FS Bronco tailgate latch assembly from the PnP awhile ago and finally finished her up. I had to make spacers for the rise on the tailgate, flip the clasp and weld it on a plate, U bolt it on, and paint it. This is a ton easier to latch/unlatch and it's a tight solid fit.
Wed Feb 19, 2014 9:59 pm |
Moab Mike
Very nice!
Wed Feb 19, 2014 10:07 pm |
Nice upgrade Shawn !
Thu Feb 20, 2014 4:52 am |
B.O.B.
Mocked up new radiator and shroud. Hopefully get off work early and finish the install. Need to get back out on the road.
Fri Feb 21, 2014 7:35 am |
Rox helped me swap out my cracked 9" housing for the '77 housing I've been sitting on for a while. Mounted the new housing back 3/4" and fixed the intermitent ARB leak. No chickens were harmed during the process but a leaf spring pin was.
Sat Feb 22, 2014 8:03 pm |
Moab Mike
Drove it until it ran out of gas on the main tank, replacing the tank with a new 23 gallon tank. Did a compression check, pulled the radiator and front accessories in preparation for pulling the engine tomorrow.
IT'S EFI TIME!!!
Sat Feb 22, 2014 8:16 pm |
Sat Feb 22, 2014 8:22 pm |
Sweet!
Sat Feb 22, 2014 8:57 pm |
Super sweet
Sat Feb 22, 2014 10:04 pm |
Colorado75bronc
Finally got to rebuild the steering column, install the collapsible steering shaft, and did a tuneup and an oil change on mine. It's the first time in 6 months or more I was able to do upgrades on it, and not just minor maintenance :)
Also Todd's is and has been with the body man for a little while, I cleaned up the chassis on his last weekend, hopefully next weekend I can drop in the engine, trans, and t-case. I promise I'll update the build thread then.
Sat Feb 22, 2014 11:05 pm |
OH I used my tail gate as a work bench yesterday. I need to stop using the bronco as a storage locker and get back to work on it.
Mon Feb 24, 2014 7:33 am |
Jar jar
Joined: Sun Mar 03, 2013 2:48 pm Posts: 76 Location: Fort Collins
Received this disk brake conversion in the mail yesterday and going to install this weekend. Sent from my iPad using Tapatalk
Thu Feb 27, 2014 5:00 pm |
Thu Feb 27, 2014 6:32 pm |
Friday
Got the tub put on a temporary frame :-) Now I can get the inside and underside lined while I'm working on the chassis.
Thu Feb 27, 2014 9:56 pm |
Fri Feb 28, 2014 2:00 am |
I've been trying to get the Bronco ready for Moab before I move. Been saving some of these upgrades for years. Here they are in order. Glass hood, '77 9" housing, fixed an intermittent rear ARB leak, WH extreme u-bolts and plates (also pushed axle back 3/4"), mustang hydroboost on firewall, 4 1/2" front springs.
Thanks go to Rox Crusher and 777mechanic for pushing me and helping get this stuff installed. The WH u-bolts and plates are massive at 5/8" each. All hardware for mounting the hydroboost was made on 777mechanic's mill. Bronco 8378.jpg Bronco 8379.jpg Bronco 8383.jpg Bronco 8380.jpg Bronco 8381.jpg
Sat Mar 01, 2014 4:55 pm |
Very nice work, Viper. That is my fav hood of all time. It's not that you were putting off your Bronco, you were helping everyone else :)
Sat Mar 01, 2014 5:35 pm |
Nice! How are you liking the power brakes?
Sat Mar 01, 2014 5:53 pm |
