It is currently Sun Nov 24, 2024 8:02 pm
ZF-5 Behind a 400 M block swap - in an Early Bronco
Sat Mar 01, 2014 10:11 am |
Re: ZF-5 Behind a 400 M block swap - in an Early Bronco
I found that in order to bleed mine completely, I had to use a pry-bar thru the inspection window and manually operate the fork. before you tear it down try that!
Sat Mar 01, 2014 11:13 am |
I bled it outside the truck as mine is external. I bet it will be fine. So far the clutch feels great but will have Kirk drive it to have a feel.
Sun Mar 02, 2014 11:46 am |
I drove it! 75 mph is about 2500 RPM.. so far so good will post up some pictures and video tomorrow as its supposed to be really nice out and build my tunnel covers.
Sat Mar 08, 2014 10:34 pm |
Colorado75bronc
Awesome! Congrats!
Sun Mar 09, 2014 1:17 am |
Sweet! That had to feel good. I can't remember, what gears are you running?
Sun Mar 09, 2014 2:10 am |
Congrats!
Sun Mar 09, 2014 8:46 am |
Congrats Landshark !
Sun Mar 09, 2014 9:37 am |
4.56 gests
Sun Mar 09, 2014 10:02 am |
Sun Mar 09, 2014 10:17 am |
Sun Mar 09, 2014 10:46 am |
You have me thinking about whether a mild EFI 351w with 4.56 and 37s could turn that .76 final drive....
Sun Mar 09, 2014 1:56 pm |
Sun Mar 09, 2014 5:04 pm |
True 37 " tires with od I would go with 4.88. But that's what worked for me in my big bronco
I think 4.56 with od and 37's you would be ok
Sun Mar 09, 2014 5:46 pm |
I'm not sure it would work all that well with the current 302, at least on anything resembling a hill. Either way, a new trans is a long way down the list of plans.
Sun Mar 09, 2014 9:10 pm |
Mon Mar 10, 2014 4:57 am |
Users browsing this forum: No registered users and 15 guests |
