It is currently Sun Sep 29, 2024 3:25 pm
[ 5 posts ] |
saginaw pump pushing out air? bleed more?
trei75bronco
Joined: Wed Jan 26, 2011 10:55 pm Posts: 837 Images: 0
So I started up my rig tonight and when I shut it down the saginaw steering pump hissed air. I have a cooler, ram , steering box. Is it just purging air?
Thu Mar 06, 2014 9:13 pm |
PaulW
Joined: Thu Nov 11, 2010 10:53 am Posts: 14 Location: Durango CO
Re: saginaw pump pushing out air? bleed more?
You will need to et the air out. Air in the system could be a leaking fitting? Keep purging. You may have to resort to a vacuum purge?
Sun Mar 09, 2014 12:04 pm |
x2. My guess is that you've already been messing with it, but you've got a lot of volume to fill. How much fluid have you put in the system so far?
Sun Mar 09, 2014 1:55 pm |
RJLougee
The pump will do that until you get all the air bled out of the system. Did you jack the front up and cycle the steering wheel, etc... to get all the initial air out? Basically, the system has to be bled like brakes do to get all the air out.
If you've done a good job getting all the air out, then continued cavitation will indicate an issue. Joe
Tue Mar 11, 2014 6:56 pm |
trei75bronco
My cooler is higher than my resivior im special sometimes
Tue Mar 11, 2014 8:51 pm |
[ 5 posts ] |
